Sponsored by: Innova
Over the Bose system
Old Aug 13, 2010 | 12:54 PM
LEAVINU's Avatar
LEAVINU
Default Over the Bose system
I've read most of the stickies around the 6.5" conversions in the C6. My question is this..... can I run four regular speakers (Polk, whatever) off my Pioneer F900BT headunit and be ok? Do I have to add an amp?
Looking for the simplest decent sounding system possible. I already have the headunit running through the Bose crap speakers and amp. Sound is blah but honestly I'm not precise sound type of listener. I popped a Bose speaker so thats the motivation of my question.
Old Aug 13, 2010 | 01:35 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ur gonna loose bass
Old Aug 13, 2010 | 05:56 PM
LEAVINU's Avatar
LEAVINU
Makes sense. Any other options other than 6.5"s? Also, will the pioneer have enough juice to push them?
Old Aug 13, 2010 | 09:30 PM
LEAVINU's Avatar
LEAVINU
Just pulled up the specs on my HU and its rated at 50*4 max and 25*4 continuous. This seems pretty weak. Am I wrong?
Old Aug 13, 2010 | 10:39 PM
NYC6's Avatar
NYC6
No, you're not wrong. Dont be opposed to adding a good amp, its money well spent and you'll be glad you did it. It will make speakers shine!
Old Aug 13, 2010 | 10:59 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I have all kinds of amps in all kinds of price ranges.
Old Aug 14, 2010 | 12:21 AM
pentavolvo's Avatar
pentavolvo
honeslty not adding an amp will make u want to kick ur self in the ***, just spend the extra money do components in the door and add an amp
Old Aug 26, 2010 | 09:22 PM
wascapsfan's Avatar
wascapsfan
Good Evening M.... I just purchased a Rockford Fosgate amp that I will hook up to a 4 ohm 12" sub in the rear and I also purchased a
Kenwood KAC-PS200T amp to run the 5 1/4" rear speakers in my Vert.
I had an old pair of JBL speakers so I removed the tweeter off of them and added it to the rear (not yet amplified) with a crossover and it sounds pretty good with the bose speaker. I can't wait to try out the amps. They just came today!!!!
Old Aug 26, 2010 | 10:16 PM
pentavolvo's Avatar
pentavolvo
what about the front speakers, please tell me u arent leaving them stock???
Old Aug 26, 2010 | 10:49 PM
wascapsfan's Avatar
wascapsfan
I just replaced the front 3.5" with a pair of Infinity 3.5" and kept the Bose 8" and crossovers. Not too satisfied yet! I expected better highs.
I'm going to add a new post to see if anyone else has had better success. I was given this idea by a member of the boards that said the sound would be much better...
Old Aug 26, 2010 | 11:09 PM
pentavolvo's Avatar
pentavolvo
u need to forget about rears, do components up front and amp em up. or atleast amp the 3.5 up front i would do that before ampin rears
Old Aug 27, 2010 | 12:57 PM
rickso84's Avatar
rickso84
I didn't think aftermarket 4 Ohm speakers were compatible with the Bose components that are 1 or 2 Ohms. A 4 Ohm speaker on a 1 Ohm output is not going to put out much sound. Are you running an aftermarket amp to the 3.5"?
Old Aug 27, 2010 | 02:52 PM
pentavolvo's Avatar
pentavolvo
??? in both the c5 and c6 the door woofer and twiddler are powered seperately and the twiddler is 4ohm
very common mod to upgrade them
To Over the Bose system
