Sponsored by: Innova
question about fm radio reception
Old Aug 22, 2010 | 06:49 PM
fressh's Avatar
fressh
Default question about fm radio reception
I've got an 06 coupe.I swapped out the factory radio for a Kenwood head unit.The radio reception was great until I put in a new amp and speakers.I tried an antenna booster, but that did not work.Anyone have any ideas on how to correct this reception issue?
Old Aug 23, 2010 | 11:09 AM
EliteGreg's Avatar
EliteGreg
FM reception on the C6 will suck unless you have the OEM headunit. I have a post about this (see my past posts about my stereo install). Basically, the car has an AM antenna an an FM antenna system (made of 2 antennas). Both are amped. By default the AM antenna is selected. You must send a signal down a certain wire at the right voltage to enable the FM antenna (separate from the 12V power antenna wire). That improves the sound, but only temporarily. It turns out, that the 2 FM antennas use some kind of phase modulation or something to improve reception, but they need a feedback from the HU. The HU varies the voltage as the car moves. So anyway, after trying pretty darn hard to use the stock FM antenna, I couldn't get it to work reliably (would get a helicopter noise). Buy a metra antenna and stick it in the back under the carpet. They are cheap and work.
http://www.cartoys.com/products/prod...D_MNT_ANTENNA/
Greg
Old Aug 23, 2010 | 06:59 PM
fressh's Avatar
fressh
Thanks,I'll try that.
Old Aug 23, 2010 | 07:26 PM
NYC6's Avatar
NYC6
What amp do you have powering it up? Is it a class D or have class D? When I initially did my system in my 06 I went with a JL 500/5 amp(with a D sub amp) my radio recetion went to crap. My installer tried telling me its normal dont worry about it. I said F.U.! This isnt normal and Im not paying for it. I ended up calling JL down in Miami and spoke to one of the big shots there. He told me that sometimes D amp affect reception in certain areas of the country and suggested I remove it and use a class AB amp.
I returned the 500/5 and from another audio place had the install a 450/4v2 and a 300/2v2 for my Stealthbox. It solved the problem right then and there.
Not saying thats your problem but something to think about.
Old Sep 15, 2010 | 09:29 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Greg
I am guessing under the carpet in rear you still get good reception, I have a C5 with after market and the signal is very weak, tried the module mod and it didnt work, this may be what I need?
To question about fm radio reception
