Sponsored by: Innova
Polk 5-channel sub recommendation.
Old Nov 24, 2010 | 09:47 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Default Polk 5-channel sub recommendation.
I'm looking at buying this polk amp.
http://www.sonicelectronix.com/item_...+PA1100.5.html
Running 6.5" MM Polks up front and some combination of subwoofers in the rear.
It gets the most power when running at 1 ohm but I'm not sure how to tell if it'll be stable at that and If I should buy subs assuming it is or not.
AMP: sub channel
280RMS@4ohm
400RMS@2ohm
600RMS@1ohm
Subwoofer options DVC or SVC with 4ohm coils.
2 x 8" DB Polks 180RMS
2 x 8" MM Polks 250RMS
2 x 10" DB Polks 270RMS
http://www.sonicelectronix.com/item_...+db840DVC.html
http://www.sonicelectronix.com/item_...+MM840DVC.html
http://www.sonicelectronix.com/item_...DB1040DVC.html
any advice? Play it safe with the DB 8's at 2ohm or go for broke and get the higher end ones and hope they run at 1ohm?
Old Nov 24, 2010 | 10:22 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
amp makes it peak power at 1 ohm. the amp doesnt dictate what it runs at, the subs determine the ohm rating.
Go with a 4 channel amp in my opinion. But if going with above amp I woudl do 2 of the polk mm 8s dual 4ohm
Old Nov 26, 2010 | 12:04 AM
PUNISHER VETTE
I was origionally looking for a 4 channel but couldn't find one with enough power that wasn't ungodly expensive(under 400) or an off brand.
Hifonics was the only brand I recognized that got mixed reviews here on the forum but had enough power for what I want...
http://www.sonicelectronix.com/item_...+%2B+RCAs.html
With mixed reviews on the Hifonics and my knowledge of car audio at zero I figured I would play on the safe side and get a brand I know and like(Polk). If enough people step up and back the use of the Hifonics I would gladly go with it to save money that I can put towards the better subs or receiver.
Old Nov 26, 2010 | 12:27 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I just hooked up my 5 channel hifonics similar to the one you posted above and it is awesome! All I got right now hooked up to it is the front alpine components and a eight inch sub until I get time to build me a box for dual 10's. As of right now I am very happy with the hifonics.
To Polk 5-channel sub recommendation.
