Sponsored by: Innova
C6 bose option who changed speakers only?
Old Jan 5, 2011 | 01:14 PM
Flexinator's Avatar
Flexinator
Default C6 bose option who changed speakers only?
Hello All,
I want to keep my head unit/nav stock but would like a relatively inexpensive mod to make the sound better, I am really disappointed at the stock bose sound, my 2002 inifiniti has better sound, I am not kidding!
Someone who has just change speakers and noticed a big difference or even a noticable difference let me know, also what brand do you recommend? I want good mid range and high, not worried about bass for now....if i can spend less than $250.00 on a set of 4 that would be great.
Old Jan 5, 2011 | 02:17 PM
NYC6's Avatar
NYC6
You will get a marginal improvement if you plan on powering them from the stock HU. There just isnt enough wattage to get really good sound. What I would do if you. Keep the HU and add a nice set of components up front and use an aftermarket 2 channel amp to power them. Possibly add nice coax's in back and use a 4 channel amp. Either way it will be worlds better than what you have now.
Old Jan 5, 2011 | 04:12 PM
snoopdan's Avatar
snoopdan
I went with Morel intetgra 8"
they're super thin neo goodness. Fills up that big hole pretty well
Old Jan 5, 2011 | 05:40 PM
Flexinator's Avatar
Flexinator
you mean a sub? the whole under the carpet?
Old Jan 5, 2011 | 07:55 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if you do not intend on adding an amp. your best bet is to do the twiddler upgrade, rear coax upgrade, and disconnect the center channel.
i recommend polk db351 and db521
Old Jan 6, 2011 | 10:20 AM
snoopdan's Avatar
snoopdan
They're not subs, they're full range speakers
Old Jan 6, 2011 | 01:23 PM
Flexinator's Avatar
Flexinator
wow, what hole were you referring too? doors?
Old Jan 6, 2011 | 01:27 PM
Flexinator's Avatar
Flexinator
thanks for info, I will def. consider them...keep it coming guys!
Old Jan 7, 2011 | 11:57 AM
nc_c5's Avatar
nc_c5
Just completed the upgrade above. Big difference in clarity and separation.
Old Feb 9, 2011 | 12:46 AM
c6_rob's Avatar
c6_rob
Really interested in this.
Does this make the system any louder? So the 521's in the front and the 351's in the back?
What exactly is the twiddler upgrade?
Old Feb 9, 2011 | 01:45 AM
markcz's Avatar
markcz
Stock setup has powered subs & 3.5 tweeter/mid (twiddler) in doors, and 5.25's in rear. The front and rear twiddlers are pretty much pathetic compared to just about any other speaker. Replacing them with 2-way aftermarkets won't make it any louder, but the sound difference is definitely noticeable. Just doing the fronts (about $50) is good enough for many people to be happy.
Old Feb 9, 2011 | 08:45 AM
thptrek's Avatar
thptrek
What do you think is a good budget to replace the front and rear twiddlers and add a 4 channel amp? I realize that you could spend X to 5X but would $500 get a good system?
Old Feb 9, 2011 | 11:41 AM
okie08vette's Avatar
okie08vette
Default My suggestion
Hey, I have a set just like that I am installing its a British brand but spec's and price are real nice. Its Vibe, "Slick". I got the whole set up from Dennis at Double D Mods, he will do you right with what ever you want. Here he is C5bearsfan, check him out.
To C6 bose option who changed speakers only?
