Sponsored by: Innova
4 OHM VS 8 OHM Sub?
Old Jan 23, 2011 | 08:37 PM
gregm999's Avatar
gregm999
Default 4 OHM VS 8 OHM Sub?
Well I've decided to go with the JW 10W1V2 sub for my Z06. This model comes in both a 4 ohm and 8 ohm version. Initially I had planned on going with the 4 OHM version, but I have an opportunity to get a really good deal on the 8 OHM one. What will the main difference be between the 8 ohm and 4 ohm version, and which one would be preferred? The AMP is a PDX 4.150 which I will be bridging two channels of, sending 300 watts RMS to the Sub. Both versions of the 10W1V2 are rated at 300 watts rms. Any advice would be appreciated!
Old Jan 23, 2011 | 08:55 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Typically an amp rated for 150W RMS at 8 ohms, will deliver 300W RMS at 4 ohms.
Can your amp deliver the 300W at 8 ohms? If so, no problem.
Old Jan 23, 2011 | 10:00 PM
gregm999's Avatar
gregm999
I'm not sure. I believe the amp is rated at 150 rms per channel at 4 ohms and ill be bridging two channels to the sub.
Old Jan 24, 2011 | 06:21 AM
nickwfd92's Avatar
nickwfd92
get another 8 ohm sub and wire in paral. to get a 4 ohm load.
With the sub you have and the the PDX if you bridge it it will be 150x1@8ohm. or 300x1@4. so with the sub you will only have half the power because its 8ohms.
My $.02 would be either sell it or get another 8ohm and wire all the +'s together and all the -'s together to get a 4 ohm load.
Old Jan 24, 2011 | 09:28 AM
Kale's Avatar
Kale
I remember reading a review that bench tested the PDX 4.150 at something like 470x2 bridged. I don't know if it was a factory freak or something, but it's good to keep in mind.
Old Jan 24, 2011 | 06:21 PM
markcz's Avatar
markcz
I've seen specs for lots of class D amps (like the PDX) that show the same ratings for 2 ohms as 4 ohms. Maybe 8 ohms is the same also, but I doubt it. Try contacting Alpine to see what they say, or just spend a few bucks more and get the 4 ohm sub
Old Jan 24, 2011 | 07:29 PM
gregm999's Avatar
gregm999
Thanks for the advice guys, think I will just go with the 4 ohm version and play it safe.
Old Jan 24, 2011 | 10:02 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
There are far better sounding subs for the money, I have shipped replacements for those and the W3 and everyone loved the improvement.
I am not a fan of D class amps, I use a tiny G class that sounds much better.
If interested give me a call tomorrow, I know how to save some real money on this stuff as well
Rick
Old Jan 24, 2011 | 10:04 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
I never can seem to remember the exact technical reasons but it is not a huge difference in out put going with a higher impedance speaker, less current draw on the amp, etc....
We all like numbers, WHP, etc....to the point even diesel guys talk about HP when torque is what makes them so cool......
Voice coils are smaller, less weight, faster response.....
Watts are not everything though I love plenty in my systems but for reasons different than might seem apparent, DYNAMICS, mainly
Rick
To 4 OHM VS 8 OHM Sub?
