I replaced the head unit with an alpine unit. I have a stealthbox in the trunk. The Blose speakers sound like ****. Whats the best route at this point? Thanks
Does your radio have a dedicated RCA sub output? If yes, I'd connect that to the sub to see if you can fine tune the levels.
-OR-
Dump the bose all together. Get 6.5" components for the doors along with a 5-channel amp if you like powered rears, or 4-channel amp to use 1&2 for doors and 3&4 bridged to sub, or 2-channel amp if you're happy with current sub amp.
You'll be amazed on how a good set of aftermarket componets will sound coming from the Bose set-up. Personally, I'm a firm believer in having a front stage speaker set with no rear speakers. When you go see a live concert they have no rear speakers, just fronts. I believe the only exception is if you plan on going 5.1 set-up, then you need rears. Best wishes
