Sponsored by: Innova
Issues with my JL Audio W7 Need Help
Old Feb 26, 2011 | 09:49 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Default Issues with my JL Audio W7 Need Help
I attempted to turn my stereo system up today and I heard what sounded like the sub (JL Audio W7) making a poping sound or distorting when I crank it up real good. so I turned it down some. When I got home I inspected the sub and I noticed that around the rubber/foam surrounding the sub its splitting? I was told that I could send the sub to JL Audio and they could recondition the sub for me? Is this true and does anyone know how much it would cost?
The amp powering my sub is a JL Audio 1000 : 1
Old Feb 26, 2011 | 10:22 PM
dgoldenz's Avatar
dgoldenz
Ouch....a re-cone on a W7 is around $350-400 plus shipping both ways if I remember correctly. Might be better off trying to find a used one locally.
Old Feb 26, 2011 | 10:55 PM
MVP'S ZO6's Avatar
MVP'S ZO6
would they uitilize butyl rubber as opposed to the current material used now? i sent them an email asking but I was hoping to know asap.
Old Feb 26, 2011 | 11:38 PM
dgoldenz's Avatar
dgoldenz
They would basically turn it back into a brand new sub with the re-cone. You might be able to salvage the surround with some type of adhesive. Contact JL...might be worth trying before paying for a full re-cone.
Old Feb 26, 2011 | 11:43 PM
MVP'S ZO6's Avatar
MVP'S ZO6
if It's 350 -400 to re-cone the sub I don't mid paying that (cuz its cheaper then a new one) however, I just want to prevent this from happening again.
Old Feb 28, 2011 | 06:03 PM
C6CorvetteZ51's Avatar
C6CorvetteZ51
It would certainly need to be reconed by JL. And its not likely they would use anything other then the original materials. Can i see pictures of your setup? box design and such
Old Mar 2, 2011 | 05:30 PM
gradykd's Avatar
gradykd
I had the same thing happen to my w7. I repaired it myself, very easy. I took the sub out the box and super glued the edges around the cone where its splitting. Make sure you leave no air gaps when glueing. After you glue the edges, turn the sub upside down on a flat surface and let sit for a couple hrs. Trust me it works. When you finally reinstall the sub, dont blast it for i say a good week. Keep it at 50%. Be aware, you will still heard a little distortion after reinstalling, but it will smooth out throughout the week. Then your sub will be back to the great quality sound.
Old Mar 2, 2011 | 07:14 PM
Kale's Avatar
Kale
You could use silicon glue too.. I've patched a few surrounds that way.
Old Mar 3, 2011 | 03:42 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Here you go.
Old Mar 3, 2011 | 09:06 AM
lionelc5's Avatar
lionelc5
WHERE DID YOU GET THAT BOX!!!!
I had a custom box built for my old C5. It was built for a 12 W7, but I ended up selling the car before I installed it.
That looks exactly like it, and I had not seen any others like it. I sold it after the car was gone.
Just wondering if that is it, and if so, how did it sound?
Lionel C
Old Mar 3, 2011 | 03:31 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Lionel C
it came with the car when i bought it. the guyi bought the car from is aaron (corvetteadk) he owned the car for about 6 months. He bought the car from chaidan (clekchaum)
Old Mar 3, 2011 | 04:12 PM
lionelc5's Avatar
lionelc5
Who knows, maybe it was my old box! Small world if it is because I am in Houston.Doy you like the sound out of the box? I can only assume you did if you worked that W7 like that.
Lionel C
Old Mar 7, 2011 | 10:45 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Lionel C
Did you sell it to someone from Texas? Because my car is originally a Texas car. As for the Whole stereo system, it rocks. Honestly anyone who has more then one of these subs in a vette is crazy. I don't think I have ever heard a more powerful single sub system (bass wise)
On another note, my sub is going back to JL Audio for repairs.
Old Mar 7, 2011 | 11:17 AM
lionelc5's Avatar
lionelc5
Yes, I am in Hoston TX. I bet that is it. And the box was made by a company in Canada. That little box sure has made its way around!
Glad it sounds good. I always regretted not getting to hear it.
Lionel C
Old Mar 12, 2011 | 10:40 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ok after talking with the folks at auto sound lab in fresno, they said that the problem im having with my W7 is common among other W7's JL recognised this and has since fixed it on thier latest version of the W7. With that said, he also said that they will uitilize their newest stuff when they repair my sub. This is a good thing. I will admit though I almost walked out of there with the memphis "mojo" sub. the ability to fix it yourself if it goes down sold me alone.
Old Mar 13, 2011 | 03:08 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
JL=far to much $$$$$$$ that repair cost is just plain nuts.......
Guys when you want a kick but sub look at the IDMAX, IQDV3, even the ID15, the JLW7 is the only sub they make that sounds as good as these, the IDMAX which gets it on very well and cost a ton less....like half!
I like the ID15 so much I have four in my home audio install, a very high end sounding system
Sorry, venting, sorry to see people spending so much on over priced gear.
Try silicone but that is a huge crack, I have used it on much smaller ones, holes punched by screwdriver nubs, etc.........worth trying though but you might have to keep it turned down a bit.
Rick
To Issues with my JL Audio W7 Need Help
