Sponsored by: Innova
carpc question
Old Mar 7, 2011 | 02:18 PM
kasper-pA-'s Avatar
kasper-pA-
St. Jude Donor '05, '14, '15
Default carpc question
Hey all,
I am about to start building a carpc to go in the 00' coupe... I have a few questions I hope someone could answer
I am thinking about using the new AMD fusion guys, specifically:
http://www.newegg.com/Product/Produc...82E16813131698 (SFW)
It's the same board i'll end up using for a replacement HTPC for the bedroom... but with that board/cpu, can I use the M2-ATX PSU or would I be better off with the M3-ATX? (really I'm confused on the PSU's for the car...)
Was also thinking about using the VoomPC-2 case, but want to make sure the case and where it is mounted will be able to take some road bumps, etc while daily driving, any suggestions on a case?
TIA!
Ryan
Old Mar 7, 2011 | 06:22 PM
jcgunn's Avatar
jcgunn
Wow,
You probably need to post this on some ubergeek forum. My suugestions would be to use a SSD and a passively cooled CPU--other than that I have no clue
Cheers and good luck, keep us posted
Old Mar 8, 2011 | 11:27 AM
kasper-pA-'s Avatar
kasper-pA-
So, I pulled the trigger on the PC parts and case for my CarPC project. I'll take pics etc when they come in and document some things. Will need to buy a 7" screen and get my bezel modified (will be going through Dennis @ doubeDmods for this) So I will post updates as I get further on with it..
cheers,
Ryan
Old Mar 10, 2011 | 12:32 AM
TNX ZORA's Avatar
TNX ZORA
I know a pc can receive good FM quality as well as TV and mp3 but can a pc perform a Nav function as well as a purpose-built receiver? Just wondering.
Old Mar 10, 2011 | 08:53 AM
kasper-pA-'s Avatar
kasper-pA-
I should be receiving all the pc parts and case tomorrow, so i will post pics. As for the software, I'm generally a linux guy, but I'm going to give "Centrafuse"(windows) a 30 day trial and if I like it will go with it.
http://www.centrafuse.com/ProductInfo.aspx?pid=129 (sfw)
they have a good amount of plugins available as well...
I'll keep y'all posted on progress.
Old Mar 11, 2011 | 12:15 AM
TNX ZORA's Avatar
TNX ZORA
This is going to be a really interesting project to follow and I wish you all the best with it. Are you reasonably confident that there's sufficient space for all the hardware that would be needed to carry out the software's full potential?
Old Mar 11, 2011 | 09:11 AM
kasper-pA-'s Avatar
kasper-pA-
Yes, I actually received the board last night. It is 6.7" x 6.7". Has bluetooth, wifi, a ATI6310, 8GB RAM, dual core - plenty of horsepower for a carpc, it streams 1080p movies in my htpc setup with no issues at 18% cpu, so that is awesome and a bit overkill .
As for the software - I'll have it tethered to my iphone when i'm in my car, bluetooth handsfree calling, option of using (via usb) GPS on my iphone, or may add a GPS antenna via USB for navigation. I have a 64GB SSD for the OS and local music storage, (SSD = very low power, no moving parts, very low heat)
I need to get an amp, and replace all my speakers, may add a sub, altho that would be last on my list. I'm waiting for the case, and then will start a new thread for the build / install with pictures. Will be working with Dennis at Double D Mods for a custom bezel that will fit a 7" touch screen.
Cheers,
Ryan
Old Mar 14, 2011 | 12:40 PM
BluV's Avatar
BluV
St. Jude Donor '09-'10
Sounds like you already have it figured out - sorry, did not see your posts earlier.
You a member on mp3car.com ? That is the best CarPC forum that I am aware of....
Old Mar 16, 2011 | 10:16 AM
bbentley40's Avatar
bbentley40
Hey Kasper, I saw your PM about the carPC stuff. I dont have my vette anymore, but I will help you with any questions I might can answer. Sounds like your getting it all planned out pretty well so far.
Old Oct 23, 2011 | 01:48 PM
mr.radon's Avatar
mr.radon
Good work! Glad to see some other people finding car PC solutions.
I run Centrafuse in my '09 Z06. I love that in the garage I can access my server and download the latest movies and music off my home's server.
I have the a 256 1.8" Kingstone SSD HD, all my digital music and a lot of .avi movies. I run a high res capacitive touch screen. Have navigation and an OBDII link. I would love to see pictures of your setup. I found lots of room after I ripped out the crappy 6-disk CD changer. Can't believe that some people actually are buying the DNX9980 and think they have a good system. LOL
To carpc question
