Sponsored by: Innova
Exhaust bolt as a ground
Old Mar 12, 2011 | 03:22 PM
Lancejoker's Avatar
Lancejoker
Default Exhaust bolt as a ground
Anyone ever use on the exhaust mount bolts in the back for a ground? I noticed it bolts directly into the frame and seems like a rather easy access location.
Old Mar 12, 2011 | 09:04 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
As long as it is mounted to the frame and cleaned off really well, best to grind down the paint or sand it off, etc...then fine. Once done spray some undercoating over it.
I have a frame mounted ground that is 12 years old and still just fine
Rick
Old Mar 12, 2011 | 10:14 PM
Lancejoker's Avatar
Lancejoker
It worked great Rick. Thanks for the help.
Old Mar 12, 2011 | 10:53 PM
markcz's Avatar
markcz
Does that mean you're almost done with your install? You've got to be going on two years now
Old Mar 12, 2011 | 11:22 PM
Lancejoker's Avatar
Lancejoker
Yeah it's been about that long that I've been collecting pieces of the puzzle. Everything is in but the sub box,which I'm working on now to hold the Hertz Mille ML3000 and I'm waiting to get my A pillars back from Audio One. Then I'll be done. Been a long road.
To Exhaust bolt as a ground
