Sponsored by: Innova
adding a eq
Old Apr 17, 2011 | 06:08 AM
madman366's Avatar
madman366
6th Gear
Default adding a eq
I have a audio control 4.1 eq i what to add to my sys but cant figure out where to mount it. If anyone who has a c6 and added a eq please let me know how you installed it.
My system
Head jvc AVX 720
Fronts Boston comps
Rear infinitys
Sub jl 12w6
JL 300/1 for fronts
JL 500/1 for sub
Rears run off head
Sounds good now but with the eq hooked up its unbeliveable
Just need some ideas on where to mount it
Thanks in advance Dennis
Old Apr 17, 2011 | 09:21 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
If you want to avoid severe dash re-molding, Your cleanest install location would be in the glove box. Considering that you will not need to do many on-the-fly adjustments, it's not a piece that needs to have easy access from the driver's seat.
Old Apr 18, 2011 | 10:31 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
I have an Arc Audio XEQ mounted under the dash, as far back as I could and still reach it with a bit of effort, passenger side, it helps the system a great deal and most do not even notice it being there.
Rick
Old Apr 19, 2011 | 03:52 AM
madman366's Avatar
madman366
6th Gear
Thanks for input guys I think i am going to try to mount it where the ashtray is hope fully the wires for heated seats switches are long enough to relocate them on main console in front of shifter also just got a new aftermarket ant to try to fix the bad fm i did power my antenna amps the way described on this forum but fm still bad
Old Apr 19, 2011 | 10:08 AM
TheRadioFlyer
Supporting Vendor
They're just switches. You should be able to easily extend them as long as you need with some light gauge hook-up wire.
What material/color is your dash?
Old Apr 19, 2011 | 10:19 PM
FrankZ06's Avatar
FrankZ06
That is an awfully big piece to mount where the ashtray is. I imagine you will have to do extensive work to the console. Another idea for you that I use to do years ago was mount it between the seat and the console. If it's not too thick, you might be able to stick it there. Another option is to mount it under the seat. If you have your amps mounted in the back, mount it back there. You can always do what I did and get an audio control EQS and mount it in the trunk.
Old Apr 19, 2011 | 10:30 PM
TheRadioFlyer
Supporting Vendor
The EQ in question is a 1/2 DIN size. Mounting solutions are numerous....getting wiring to them is another story
To adding a eq
