Sponsored by: Innova
Recommendations please
Old Apr 23, 2011 | 05:06 PM
rudyshafa's Avatar
rudyshafa
Default Recommendations please
I'm thinking of installing the following system into my 2000 C5 Vert.
JVC KD-NX5000 in dash nav unit
Polk Audio db6501 6.5" 4ohm door speakers in Madvette mounts.
Polk Audio db1240 12" 4ohm sub in a rear Madvette sub box.
Running all new wire and of course doing the insulation before its complete.
My Question is twofold.
1. Should I install rears too or will the sub overpower them?
2. Suggestions on amps? I'd kind of like to only use one if possible. I don't really want to spend a crazy amount of money but I want better sound than the after market HU and stock speakers.
I know nothing about sound systems. I am going off of pure research on this forum so I am open to suggestions. I am piecing this system together a little at a time.
Thanks all as always
Old Apr 23, 2011 | 05:53 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ditch the rears... where are you planning on puttin amp and what is budget for it. talk to dennis c5bearsfan he has those boxes and door mounts in stock
Old Apr 23, 2011 | 07:48 PM
rudyshafa's Avatar
rudyshafa
OK, so no rears.
A good mid priced amp is what I'm looking for.
I would rather do it with one amp that drives both the doors and the sub. How many channels and what watt will drive them all with no problem?
Old Apr 23, 2011 | 11:00 PM
markcz's Avatar
markcz
Get a 4-channel amp for what you want to do. Ch 1&2 will be for fronts, then bridge 3&4 together for the sub.
If you later decide that you miss the rears you can use the radios internal amp to run the stock rear speakers for a bit of fill.
Old Apr 23, 2011 | 11:28 PM
rudyshafa's Avatar
rudyshafa
Cool, thank you. Can you suggest a size and a couple of manufactures please?
Old Apr 24, 2011 | 05:07 PM
markcz's Avatar
markcz
Google the Kenwood XR-4S amp, if you like it contact member "C5 BearsFan", he owns DoubleDmods.com and can hook you up with a great price
Old Apr 24, 2011 | 05:28 PM
pentavolvo's Avatar
pentavolvo
agreed xr4s would be good
To Recommendations please
