Sponsored by: Innova
adding only a sub for c6
Old May 23, 2011 | 11:40 PM
msnbound's Avatar
msnbound
Default adding only a sub for c6
anyone here just had sub only without changing any of the speakers with the original nav bose system??? how do you like the sound?? does the sub overpower the stock speakers??
thanks
Old May 24, 2011 | 04:14 AM
WAwatchnut's Avatar
WAwatchnut
Can't speak to the Bose system, but I planned on completely changing my base system. Installed the amps and sub first (only connected the sub amp). I ended up leaving it that way for 2.5 years.
You should be able to set up the sub so that it complements the stock system. Low end reinforcement. You won't use the sub to it's full potential (depending on which gear you use), but it should definitely benefit the system.
Old May 25, 2011 | 04:03 PM
C6CorvetteZ51's Avatar
C6CorvetteZ51
Sub only is a great idea if you want more low end. If you dont have a problem with the bose, there is no reason to replace them.
Old May 26, 2011 | 03:53 AM
silver hatchback's Avatar
silver hatchback
8th Gear
So I want the lower end and have an adjustable input level control on my sub amp. Is there any reason (distortion-voltage input, etc) that I should not tap off the input signal to the door subs instead of tearing out the whole head unit? If the new sub sounds as good as I think I will tap off the right door sub signa, the existing door subs will be disconnected (later to be replaced by 6.5 c/w supply amp with full RCA install from head unit. I have already tapped the 3.5 output signal with crossovers to new 1"tweets up front. (again upgraded when 6.5 install is complete.
Thanks, what better sound now.
Old May 26, 2011 | 04:29 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
get the full range signal from the headunit, IMO otherwise it will sound like ****
Old May 26, 2011 | 05:26 PM
silver hatchback
8th Gear
Default Yuck
Nobody wants **** in their corvette, unless it's in the seat beside you
To adding only a sub for c6
