Sponsored by: Innova
Sub Wiring ?
Old May 31, 2011 | 01:27 PM
ReosLS2's Avatar
ReosLS2
Default Sub Wiring ?
Hi...
My Amp installation instructions only show how to wire one Sub but I need to wire two.It's a 2 channel Discus Amp and it says.."each model is capable of 4 Ohms or 2 Ohms operation per channel, or 2 Ohms mono."
My Subs are 2 Ohm SVC's...I'd really appreciate the Help.
Old May 31, 2011 | 02:18 PM
WAwatchnut's Avatar
WAwatchnut
You should be able to just wire one 2 ohm sub off each channel of the amp. Pretty straightforward. Which model amp is it? Are you running any other speakers off the amp?
Old May 31, 2011 | 02:38 PM
ReosLS2's Avatar
ReosLS2
That's what the guy from Subthump just told me...Thanx for the reply
Old May 31, 2011 | 08:20 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
wire each coil up to 4 ohms then parallel them together and run the amp bridged
Old May 31, 2011 | 08:35 PM
taahring1's Avatar
taahring1
thats for dual voice coil subs
Old May 31, 2011 | 08:57 PM
pentavolvo's Avatar
pentavolvo
my bad read it wrong. i woudl series and run it 4ohm bridged
Old Jun 1, 2011 | 01:19 AM
ReosLS2's Avatar
ReosLS2
Default Success
Success !!AND it only took me 3 days .Thats right expert here.It's a "Discus" Amp and I wired it separately to each channel ,maybe I'll try the series and bridging it down the road...I have a tiny bit of RPM dependant whine (I did reground H/U, Amp ground is good, RCA's are run apart from power) but I can probably live with it...thanx
Old Jun 1, 2011 | 12:29 PM
markcz's Avatar
markcz
A ground loop isolator should get rid of the alternator whine.
http://www.parts-express.com/pe/show...number=265-012
Old Jun 1, 2011 | 03:27 PM
ReosLS2's Avatar
ReosLS2
Default isolator
I'll do that ..thanx.
Old Jun 1, 2011 | 04:00 PM
WAwatchnut's Avatar
WAwatchnut
Or you might try grounding the RCA to the H/U chassis.
To Sub Wiring ?
