Sponsored by: Innova
C5 Interior Removal
Old Jun 5, 2011 | 09:52 AM
BACNBLK's Avatar
BACNBLK
Default C5 Interior Removal
Seen quite a few good posts on Door panel removal etc..
But wondering if there are any detailed threads or Books on the complete disassembly for the coupe?
Seems like everything is simple pull and snap, not seeing very many screw locations, but before I start pulling and breaking everything was wondering what might be out here?
Mainly looking at side rails , front/rear pillars and cargo hatch side walls.
Thanks!
Old Jun 5, 2011 | 10:52 AM
Kale's Avatar
Kale
Pretty much the only thing that's a bit tricky is hte hatch struts. There's a retaining clip at the top.
Go slow and be very careful. The plastics in the corvette are extremely brittle. Try to pull lightly to feel where various panel clips are then pull STRAIGHT OUT. If something feels totally stuck, there's probably a pin or a screw!
Make sure you have a panel pulling kit, it helps a ton. Harbor freight sells a plastic kit for about $8
The pillars just pop off. You pull straight back then up in one motion. Be VERY careful, the tips (thin parts atwindshield) are amazingly easy to break. Ask me how I know.
The side rails, if they are what im thinking of - they just pop out too. All panel clips.
Same with the hard carpet in the back of hte coupe. There's two hooks for the cargo shad,e htey unscrew, then hte carpet panels pop off.
Old Jun 5, 2011 | 11:26 AM
BACNBLK's Avatar
BACNBLK
Thanks Kale!
Any chance you still want lose the old 8" stealth box?
Old Jun 5, 2011 | 11:35 AM
Kale's Avatar
Kale
yep, im stuck at work all weekend though to support an issue.
Old Jun 5, 2011 | 11:56 AM
BACNBLK's Avatar
BACNBLK
Damn that sucks, sorry to hear that,
No worries, and no rush, still got wiring to get through!
Thx!
Old Jun 5, 2011 | 12:00 PM
Kale's Avatar
Kale
I'm usually in roseville on weekdays after 5pm, so if you're working up that way it's totally convenient for me to swing by next week.
Old Jun 5, 2011 | 12:09 PM
BACNBLK's Avatar
BACNBLK
You betcha, work in Roseville right by Costco,
PM with number attached!
Thanks!
To C5 Interior Removal
