Sponsored by: Innova
low volume
Old Jun 7, 2011 | 02:29 PM
car48nut's Avatar
car48nut
Default low volume
I posted this over on tech section and then found this section. I changed my c5 radio back to stock from an aftermarket one. re connected all wires and now I only get a couple of stations and really low volume. Any ideas? Thanks
Old Jun 7, 2011 | 03:12 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
sure you plugged ALL of the connectors in. There is an antenna wire, a main conner, then 2 smaller ones if i recall correctly
Old Jun 7, 2011 | 04:28 PM
markcz's Avatar
markcz
Check fuse 24 in the footwell.
If that's not it... Does it sound like the door subs are playing? If not, you probably don't have the 12v trigger from the radio. Schematics are HERE, see if you can verify that the Bose Processor and door subs are getting 12v.
Old Jun 7, 2011 | 06:57 PM
car48nut's Avatar
car48nut
I checked the fuse and it is good. All speakers are playing, just really,really low. If I turn on the car the radio will not play. When I start the car,after about ten seconds the radio will play on low. After I shut the car off the radio will still play on acc. , but still low.
Old Jul 3, 2011 | 09:40 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default low
my plays low as well.....
Matt
To low volume
