Sponsored by: Innova
Aftermarket Nav
Old Jun 8, 2011 | 11:34 PM
JLB768's Avatar
JLB768
Default Aftermarket Nav
Just bought a 2011 LT2 Coupe, and want to install a indash nav. I'm fine with the speakers that are in it, just want to pull the head unit, and replace it with a NAV that has Bluetooth. What parts would I need, and any special things to watch out for. I was a professional installer for 12 years, but haven't done it since I moved out of california in 94. Between installing, and shooting, I don't quite hear in stereo anymore, hence the reason for not upgrading speakers/amp. Simply want to pull the stock stereo, and install the Nav.
Old Jun 9, 2011 | 01:52 PM
Craig P's Avatar
Craig P
Based on my great experience....
I would give Dennis at DoubleDMods a call (608-568-3011). He is a supporting vendor known as C5 BearsFan on here. He will help you choose the best head unit based on what's important to you and set you up with everything you need at the best prices....and give you install help if you need it.
Good Luck!
Old Jun 9, 2011 | 02:09 PM
JLB768's Avatar
JLB768
Good Luck!
Thank you, I appreciate the advice, I'll give him a call.
To Aftermarket Nav
