Sponsored by: Innova
Amp cutting off
Old Jun 10, 2011 | 03:57 PM
krzytrain's Avatar
krzytrain
All Aboard!!!
Default Amp cutting off
I have a 900 watt Rockford amp that keep shutting off on me. I think it is getting hot, it shuts off then a couple minutes later it comes back on, then runs a little longer and shuts off again. This amp is about 8 years old and has been used in 2 differant vehicles, could it just be worn out?
I have the amp mounted behind the waterfall in my vert and grounded to the bolt under the waterfall cover. I have a #3 wire ran from the battery to a terminal block behind the drivers seat and a #8 wire ran from there to the amp for power. I did this so if i ever wanted to add a amp i would have everything i needed right there. The amp is powering a 10" sub in the back and my components in the doors, the sub is bridged.
Im also noticing the lights in the car dim a little when bass hits.
if im missing any info you guys need just ask.
Thanks in advance for your help.
Steve
Old Jun 10, 2011 | 04:21 PM
markcz's Avatar
markcz
Try turning the gain ***** down (approx 30* ?) to see if that helps.
Old Jun 10, 2011 | 07:11 PM
EVRose's Avatar
EVRose
I had a 10 year old Kenwood mono amp that did the exact same thing. Before I started digging through wires I just replaced it with another amp I had sitting in the garage and that one worked fine. I took the bottom panel off the Kenwood and there was a lot of corrosion going on all over the place so I just tossed it figuring with 10 years of use I got my monies worth out of it.
Old Jun 11, 2011 | 12:19 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
what model is your rockford?
Old Jun 13, 2011 | 06:08 PM
krzytrain's Avatar
krzytrain
All Aboard!!!
Ive tried turning the gain down on the amp and it still does it.
I will look and see what the model is of the amp when i get home. i know it is a minimum of 8 years old. this is the 2nd vehicle it has been in.
I always see people that have their amps enclosed in fancy cabinets and i would like to build something for mine but i know that amp gets really hot.
Thanks for the help so far guys
Old Jun 14, 2011 | 04:29 PM
VET IT B's Avatar
VET IT B
You could wire up a auxiliary amp fan for some cooling.
Old Jun 14, 2011 | 05:29 PM
Rob04C5LM's Avatar
Rob04C5LM
Hmm...at 8 years old with this problem, I'd look at replacing the amp rather than trying to diagnose and resolve heat issues. They have gotten a lot more efficient (so that heat problem is largely mitigated) and since you've already got the car wired up, shouldn't be too much cost or hassle to replace it.
Old Jun 14, 2011 | 06:33 PM
krzytrain's Avatar
krzytrain
All Aboard!!!
I think im gonna start looking for a new amp... Thanks for the help everyone.
So does anyone have a good suggestion for a descent amp to power a 10" sub and my components that are in the doors. The sub is a rockford and the components are ummmm i cant remember
Should i look for 2 amps and maybe just have one to power the sub and the other one to power the components and the rears? Any suggestions? I know my rear speakers are 5.25 hertz speakers.
Old Jun 14, 2011 | 08:48 PM
markcz's Avatar
markcz
I love my new Kenwood XR-5S amp (4x80 + 350x1)
PM member C5 BearsFan, he can hook you up with one at a great price
Old Jun 15, 2011 | 04:21 PM
1redz06's Avatar
1redz06
JL makes an amazing HD900/5 amp. Little pricey through JL but you can get a good deal on some brand new ones through Ebay. http://mobile.jlaudio.com/products_amps.php?amp_id=537 There is also the JL XD700/5 depending on your budget.
Old Jun 23, 2011 | 11:45 PM
Tyteflows's Avatar
Tyteflows
my guess is that your are bridging that amp into a lower impedance that is stable for that particular model amp.
To Amp cutting off
