Full Active or Semi Active?
here is what I have
Tuner:
Nakamichi CD400
Amps:
2x Arc KS 300.4
Front Stage:
1" Tweeter 4" Mid, 6.5" Midbass
Rear:
6.5" woofer (might swap to an 8")
Current setup has one amp bridged to the rear and one amp bridged to the front with a 3-way Passive per side
I just bought a XM6 which will give me the last piece to go active in one of 2 ways:
Active Option 1:
Amp 1
2 channels to a passive for the 1" and 4" (I have a set of 2 way passives)
2 channels for the 6.5 midbass
Amp 2
Bridged for the Woofers
Active Option 2:
Amp 1
2 channels for 1" tweeters
2 channels for 4" midrange
Amp 2
2 channels for 6.5 midbass
2 channels for Woofers
Active Option 1 uses the XM6 for crossover duty and a Passive for the 1"/4" combo
Active Option 2 uses the XM6 as well as the crossovers on the Arc for the midrange and midbass along with the XM bandpass. The XM6 with be the high low bandpass overall and the Arc the Low pass the midbass and high pass the midrange
AMP Specs:
Power output RMS @ 4 ohms 4 x 90 watts
Power output RMS @ 2 ohms 4 x 175 watts
Power output RMS @ 4 ohms bridged 2 x 350 watts
Thoughts and/or opinions?
woofers will be fine with either config
and yes the XM6 is Coustic XM6
Based on the speakers, I would go with setup two. and eliminate all the passive crossovers.
but I would recommend looking at other processors options that will give you more tuning and adjustability options and better filtering.
Bryan
For now, I just want to remove the passives, I was looking into a pair of 2x4 MiniDSPs with the parametric option, but the cost for a basically new, unused Coustic XM6 was a good deal.
I do think that putting the Coustic XM6, while it may not be the greatest or the best, beats the Passives it will replace
Reason I asked about option one was I felt the 90W per tweeter was a bit much, while 90W per rear woofer, might not be enough.
I do want to be able to hear it @ 65mph with the roof off
G'luck man
Fej
The Coustic piece will definitely be better than the passives that is for sure and to fit within your current budget then by all means start with that. when you look to upgrade beyond that look for a processor that is going to give you the ability to use time delay to equal out the arrival time of all the speakers to help accomodate for the differences in path lengths.
The Arc amp should be plenty of power to the midbass as well. they typically rate the amps conservatively so they will be good power there.
