Performance at What Volume Level?
I have spent quite a bit of cash on professional installation of amps (JL 500/1 v2 & ARC Audio mini-4ch), subs (2-JL 10W3V3 in sealed boxes), 6.5 components (ARC Audio), 5.25 rears (Hertz coaxials), and sound deadening, plates for doors, etc. (from Rick at Raamaudio). My system seems to really begin to put out power with the volume control at half power or above. It seems to me that with all the good quality audio equipment I have, it should kick azz at volume levels way before this.
Am I expecting too much from this system? Have I just gotten used to the higher volume? Is there something I should check? I listen to only rock music (alternative, metal, hard rock, classic rock, etc.) and I like it really clear sounding and loud
If my clothes and hair are vibrating from the bass in the car, that is all too fine with me! It just seems that I have to turn the volume level too far up to get performance out of this system.Let me know what you think?
Thanks!
Seriously though.... First, volume controls in today's head units are not usually linear. So halfway up, isn't really halfway up. Second, does it really matter at what point it begins producing power?? What really matters is at what point it makes full power. That point should be at (near) all the way up on the vol control.
You could increase the gains so that everything puts out more power sooner on the dial, but then you could create clipping at the top volume settings, and cause lots of damage to your system. You also potentially impact the signal to noise ratio if the input gains are turned up higher than they need to be.
If all the way up on the vol is all the way up in the power, everything is probably the way it should be. My Kenwood has a 35 step vol control. Normal listening level doesnt even begin until 22-23. At 27 it's loud. At 30 it's really loud. The decks output just isn't linear compared to the volume control.
(BTW... Vol controls may not be clean when turned up all the way, so most people don't use or tune to the highest levels... I was just simplifying things a bit)
In any event, I will check out amps' settings to see where the gains are set. May want to adjust these up a little to get more power earlier into the volume dial if that would help.
