Sponsored by: Innova
Bezel issue
Old Jul 19, 2011 | 11:09 PM
Roodman's Avatar
Roodman
Default Bezel issue
The Bezel that surrounds my radio on the passenger side towards the top by the radio has never fit properly. You can push it to where it belongs. Its 3-4mm out. Is there a spacer I can put the fix it or bend it carefully, just wanted your guys opinion.
Old Jul 19, 2011 | 11:56 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Put some black tape around top right tab and cut off the insert pins will set flush
Old Jul 20, 2011 | 07:17 AM
Roodman's Avatar
Roodman
When I get it off ill have to make sure Im cutting the right thing. Im sure when its off ill see it. What will the tape do and the insert pins which are lower I assume are too long so they are holding it up?
Old Jul 20, 2011 | 07:22 AM
0Double D Mods
Former Vendor
tape will give the top tab some thickness and make it tighter fitting on dash
pics are more than likely to this to insert in the holes in mounting cage to allow it to be pushed in far enough. Just something from the mold when it was made
To Bezel issue
