Sponsored by: Innova
Good rear grounding location
Old Apr 27, 2002 | 04:22 PM
c5a4's Avatar
c5a4
Default Good rear grounding location
I ran 4gauge power cable to the back and now am looking for a good ground point? I read other post about the screw between the rear compartments is the good for two amps about 800 watts total. I have 4gauge ground cable and distribution blocks. Oh yeah its a 98 coupe.
Old Apr 28, 2002 | 01:59 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Good rear grounding location (c5a4)
Seat bolt that bolts seat to floor pan. (The bolt itself) Is a solid 12 volt ground. :yesnod:
Old Apr 28, 2002 | 03:47 AM
mrkln's Avatar
mrkln
Default Re: Good rear grounding location (The^Nomad)
You can drill through the center well and ground to the rear bumper just above the exhaust tips (DpC5 did this, contact him for more information) or run the ground back to the battery. I chose to run mine back to the battery. :cheers:
[Modified by mrkln, 1:48 AM 4/28/2002]
Old Apr 28, 2002 | 08:35 AM
DPC5's Avatar
DPC5
Default Re: Good rear grounding location (mrkln)
Here is where I went to - I'm running Soundstream amp's (1600 watts total)
To Good rear grounding location
