Sponsored by: Innova
Aftermarket Stereo Issue
Old Aug 19, 2011 | 02:28 PM
Dowatt's Avatar
Dowatt
4th Gear
Default Aftermarket Stereo Issue
A week ago I had Bestbuy install a dvd flip out HU in my 97 C5. I do have the Bose factory system, I asked him if I needed to get the bose interface/adapter and he said no. They installed the new radio but it hardly had any bass output ( the factory radio sounded much better). I turned around and went back and they tore it back down again. This time I did have bass however on my way home the sound would go out if I turned the volume way up. No matter if it was the radio, dvd or usb the sound would go out if turned up. I would have to restart the radio for the sound to come back. I believe the bose amps are clipping under load. I've done a lot of reading since this happened and can't find anything on what can happen if the interface/adapter isn't used. Bestbuy will be putting this interface in for me (free of charge) this weekend. Has anyone had this issue? Shouldn't installing the interface/adapter fix my issue? I think it may be from the difference in omh's between the aftermarket radio and the bose system. Please let me know if this sounds like I'm on the right path.
Old Aug 19, 2011 | 02:57 PM
VetteNoob's Avatar
VetteNoob
Originally Posted by Dowatt
..... I asked him if I needed to get the bose interface/adapter and he said no. ....Bestbuy will be putting this interface in for me (free of charge) this weekend. .....Shouldn't installing the interface/adapter fix my issue?.....Please let me know if this sounds like I'm on the right path.
You need the interface if you have the Bose system. Once the interface (PAC ROEM-VET1) is installed and adjusted correctly, you'll be good to go.
Old Aug 19, 2011 | 06:49 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
they tried to bypass bose sub amp probally an parallel the tweets with the woofers or some other screwy wiring
Old Aug 20, 2011 | 05:07 PM
Dowatt's Avatar
Dowatt
4th Gear
FIXED!! Bestbuy installed the interface/adapter and all is well, sounds great! Lesson learned....
To Aftermarket Stereo Issue
