Sponsored by: Innova
Everything needed
Old Aug 30, 2011 | 11:55 PM
ZAKsPop's Avatar
ZAKsPop
Default Everything needed
OK I am wanting to swap out my 2007 factory 6disc changer w/Bose and no Onstar with a Pioneer AVIC-X930BT HU.
Here is the list of things I think I need. Can any of you audio pros' correct any mistakes or omissions?
Metra 40-GM10 Antenna Adapter
Metra 95-3304 DDIN Kit
Pioneer CD-IU51V iPod/iPhone Cable
Metra Axxess ASWC Steering Wheel Control
Wiring Harness (PAC C2R-GM24)
Backup Camera (Audiovox Car ACA200W)
Pair Ground Loop Isolators
I am not wanting to swap out the speakers or add a sub right now.
Old Aug 31, 2011 | 12:58 AM
markcz's Avatar
markcz
Looks good to me
The only possible issue I see is the steering wheel interface. Compare the one you have listed to the PAC SWI-PS to see which you like better.
Old Aug 31, 2011 | 01:08 AM
ZAKsPop's Avatar
ZAKsPop
Originally Posted by markcz
Looks good to me
Well I looked at that one too but this one requires no complicated programming. I just want it all to work.
Old Aug 31, 2011 | 01:36 AM
WAwatchnut's Avatar
WAwatchnut
It'll be good to have the ground loop isolators handy, but you may not need them. Make sure you try it with and without them installed.
Old Aug 31, 2011 | 04:55 PM
ZAKsPop's Avatar
ZAKsPop
if I have them handy should I not just install them? Will they cause any issues if they are installed if they are not needed?
Old Aug 31, 2011 | 06:01 PM
WAwatchnut's Avatar
WAwatchnut
Any unnecessary items inserted in the signal path have the potential to degrade sound quality. Some people indicate they have heard a difference in sound quality with the isolators installed. I've only had to use GLIs 2x in my life, and I used to own a car stereo shop. Most of the time if there is engine noise, it's because something is installed incorrectly. It's a little more difficult now, with so many different audio components tied into the cars electricals, but when I upgraded my c6, with multiple amps, a sound processor, and various iPod, nav, and BT moduleS, no engine whine is present. OnStar seems to be a contributing factor, and since you don't have that, the GLIs may be unnecessary.
Old Aug 31, 2011 | 08:00 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if you dont need them you will be the .01%
Old Aug 31, 2011 | 08:19 PM
kedar's Avatar
kedar
St. Jude Donor '12
With stock nav and aftermarket speakers and aftermarket amp I had noise in my system. The solution was grounding rca's to head unit (thanks pentavolvo) and getting an antenna isolator (with adapters to connect it to stock antenna wire and head unit).
Old Sep 17, 2011 | 04:32 PM
Rbohno's Avatar
Rbohno
[QUOTE=ZAKsPop;1578565915]OK I am wanting to swap out my 2007 factory 6disc changer w/Bose and no Onstar with a Pioneer AVIC-X930BT HU.
end [Quote]
This is the same setup I am about to install, I deleted the steering wheel controls that were listed above because I dont have that option.
I have a 2006 3LT coupe non/nav Bose
My question would be would it make any sense to go ahead and replace the 3.5 door speakers (leave the 10's alone) and also replace the 5.25" rear speakers. Would I benefit much by changing the stock speakers mentioned?
Old Sep 17, 2011 | 07:00 PM
markcz's Avatar
markcz
Replacing the oem 3.5" speakers with aftermarket 2-ways gives a modest improvement in the highs up front. Swapping the rears is pointless if you're still using the oem amp setup (which you are by the gear you say you're using).
Old Sep 17, 2011 | 07:05 PM
Rbohno's Avatar
Rbohno
Thanks for the advice so I may just go with the front speaker swap for now.
To Everything needed
