Sponsored by: Innova
HEY Kale Drivers door tweeter>>
Old May 1, 2002 | 03:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default HEY Kale Drivers door tweeter>>
you were right..
I cannot here the tweet in the drivers door.
Any suggestons of where else to try?
Old May 1, 2002 | 04:02 PM
Kale's Avatar
Kale
Default Re: HEY Kale Drivers door tweeter>> (-=Jeff=-)
Hmn... Maybe you can pillar mount them? Get a custom pillar done so they look factory.
The idea is to get them as far away from your face as possible... hmn...
Willing to cut your door panels?
[Modified by Kale, 2:05 PM 5/1/2002]
Old May 1, 2002 | 04:13 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: HEY Kale Drivers door tweeter>> (Kale)
I want to make custom pyramid shaped resin or fiberglass boxes the size of the tweeters that fit between the dash, windshield, and A Pillar. I'll get around to it someday.
Old May 1, 2002 | 04:58 PM
-=Jeff=-'s Avatar
-=Jeff=-
Maybe.. that was my original intention but still debating if I want to
Old May 1, 2002 | 05:00 PM
Kale's Avatar
Kale
if you did, i'd two-sided tape them to find the best position
and put it in the top half, the most forward in the red you could.
:confused:
it is my understanding the tweeter should face the opposite person if possible.
I'd be happy to photoshop that tonight if you'd like.
[Modified by Kale, 3:01 PM 5/1/2002]
Old May 1, 2002 | 07:46 PM
-=Jeff=-'s Avatar
-=Jeff=-
:confused:
If you could that would be great!!
Old May 1, 2002 | 10:28 PM
Kale's Avatar
Kale
i had to photoshop the tweeter because of the angle.
Old May 2, 2002 | 09:37 AM
-=Jeff=-'s Avatar
-=Jeff=-
Cool, That just may work. I will have to see if there is enough space there for the tweeter behind the panel
Old May 2, 2002 | 10:12 AM
92TripleBlack
Should be fine for space. Just remember, the door panels these days are close to $500 a pop for new ones. Don't want you to do anything you might regret later. But that is pretty much the ideal location on our cars.
Old May 2, 2002 | 10:19 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: HEY Kale Drivers door tweeter>> (92TripleBlack)
I totally agree, I still need to decide what to do.. all I know is the tweeter just is not doing it down there in the door. I will have to wait and see
Old May 2, 2002 | 10:25 AM
92TripleBlack
Most tweeter makers also make "pod" mounts. These are mounted with one or two screws. You could take out a screw from the "A" piller trim piece, and use this hole to screw in the tweeter. Then the wire could run behind the trim piece and under.(tweeter wires are ususally very small gauge wire so it would be almost invisible. This was another possibility I was thinking over for mine. It just doesn't look as clean as a flush mount.
Old May 2, 2002 | 10:49 AM
-=Jeff=-'s Avatar
-=Jeff=-
Where might I find one of these pod mounts?
[Modified by -=Jeff=-, 8:49 AM 5/2/2002]
Old May 2, 2002 | 11:17 AM
92TripleBlack
What brand tweeters are they?
Old May 2, 2002 | 11:29 AM
92TripleBlack
http://www.bostonacoustics.com/library.asp
Go to this site, click on ProSeries .5 components under car speakers, and turn to page 6 of the manual. It has an exploded view of a pod for the boston brand speakers. Most makers have these mounts for their tweets.
Old May 2, 2002 | 11:39 AM
-=Jeff=-'s Avatar
-=Jeff=-
Orion HCCA 5s. The tweeters look kind of ugly and big compared to a set of Infinity's that I have (not kappa)
Old May 2, 2002 | 11:51 AM
92TripleBlack
They make the mount. They call it a surface mount. Contact orion at http://www.orioncaraudio.com and have them ship you some or at least send some pics. They should only be $5-10 each at most.
Old May 2, 2002 | 11:54 AM
-=Jeff=-'s Avatar
-=Jeff=-
Yeah I think I have a surface mount piece, but not one that makes the pod shape.. I will have to call them
To HEY Kale Drivers door tweeter>>
Old May 5, 2002 | 03:24 PM
gcrouse's Avatar
gcrouse
Jeff- here's what worked for me; tweeters are high up, cross-fired, and sound great . I have the older dash and the tweeters tuck right up under the dashpad with the doors closed. This is a surface mount wedge (Vifa) which allows 30 or 60 degree aiming; after you attach it to the panel the tweeter just snaps in.
Old May 5, 2002 | 03:57 PM
Kale's Avatar
Kale
Default Re: HEY Kale Drivers door tweeter>> (gcrouse)
Hey Gcrouse, i was thinking of angling my drivers like that. How did you make the mount?
Do you get any resonance with that set up?
Old May 6, 2002 | 07:07 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
I did my setup like this:
I have a 3-way component setup with Image Dynamics CX62 (2-ohm) 6.5” midbass drivers in the doors.
Image Dynamics 4” mids and 1” tweets in the dash. (I mounted them in the stock 4x6 location in the dash with just a little modding). The tweets are angled to face my rear view mirror. Excellent staging from that position and I didn’t have to cut anything in my interior. ;)
You basically want your tweets as close to eye level as possible. That setup gcrouse has looks like good angling too. Good job gcrouse! Looks Good! Is that fiberglass you used to make that mid enclosure? :cheers:
