Help with 1986
1. If this was originally Bose, it would say that on the grills, correct? I found a standard looking 6 x 9 in the rear and no evidence of an amp near the speaker.
2. The Delco rear stockers are 10 ohms. I am looking at an aftermarket head unit that suggests 4-8 ohm speakers. Stockers won't work, correct?
3. What would be the outcome if I tried to use stockers if they aren't blown?
4. Should I be looking for 4 ohm speakers or 8 ohm speakers? What is the deal there...are they offered in various ohm ratings?
5. Will a standard 6 x 9 fit nicely into the rear openings or will I need to modify?
6. What size are the front speakers in my car? I haven't tried to get at them yet on the dash.
7. I have never seen "A" and "B" designations on the connectors before. Which one is considered positive? I guess as long as I maintain polarity, right?
Thanks for your time and assistance with my idiotic questions.
[I]Yes[/I]
This is a normal replacement speaker, most likely 4 ohm hooked directly to the HU. The stock speakers are all 4"
See answer # 1
As a guess you don't have the stock speakers in the car anymore
Your replacement HU wil dictate what ohm speakers you get but you can pretty much bank on 4 ohm
Looks like you already have that
The dash speakers are 4x6 and you have to pull the dash pad to get at them. The grills do not come off
Yes you must maintain polarity. No clue about the A & B markings. Good speaker wire will be marked on the casing. Generally the positive side will have a white line or better speaker wire will have "+ "s stamped on it
