Sponsored by: Innova
Car Pc help for c6
Old Oct 7, 2011 | 08:18 AM
Badal's Avatar
Badal
5th Gear
Default Car Pc help for c6
Hello everyone, I have been researching a lot about this and almost have all the parts needed for this project. I have a double din 7" lcd that i will be installing in the dash and connect it to my m11x alienware netbook using hdmi. Now I am running into 2 problems, first how to power the laptop. I could get a dc to ac converter and just use the normal home power adapter or a car cigarette adapter for this laptop. Is one way better than the other in any way?.
Second problem was where to store the laptop in the car?. I will be controlling it with touch screen so don't need access to it.
This is for a 2005 c6
Old Oct 7, 2011 | 02:57 PM
markcz's Avatar
markcz
What's your plan for how everything powers up/down with the car on/off/RAP? That will determine how it gets powered.
If the audio amp isn't controlled by switched or RAP power you might have an issue with the car battery going dead.
Do you have a solution for how to start up the computer from all-off with only the touch screen handy?
Old Oct 7, 2011 | 07:50 PM
Badal's Avatar
Badal
5th Gear
For the PSU everybody at mp3car uses carnetix so i think that is the route i am going to go as well, It does say it will turn the computer on itself but i don't have the option where it turns on when ext power is present. It does wake up from a usb keyboard from sleep so maybe an ultra mini usb input device to bring it back.
However since i only need the carnetix for powering the laptop , can i just buy a normal dc-dc inverter and use the laptop's home charger to it directly?
Laptop has 5.1 out so it will connect directly to 2 amps for front, rear and a sub output. I didn't even think about the amps draining battery , What kind of a controller do i need to prevent that?
Old Oct 7, 2011 | 10:45 PM
markcz's Avatar
markcz
The easiest thing IMO for the amps would just be to power them off RAP or normal switched power, but add an additional bypass switch (possibly controlled from the computer) if you want to run them when the car is off.
Honestly, the guys on the other forum know much more about car pc's. Most of what we deal with here is vette specific, and very few have done a full blown pc.
To Car Pc help for c6
