Sponsored by: Innova
XM - no signal
Old Oct 10, 2011 | 10:42 AM
cstapp99's Avatar
cstapp99
Default XM - no signal
Just bought a 2005 c6 with the factory Nav/XM/Bose head unit. Activated XM online today, and now I see that I'm getting no XM signal. Any suggestions on how to troubleshoot this?
The XM screen just continually reads "No Signal."
Old Oct 10, 2011 | 04:13 PM
markcz's Avatar
markcz
Any chance you're in a garage or under heavy trees? If yes, drive out to an open road and see if you get reception.
If nothing, check the antenna connections on the XM box. It's located under the plastic overhang that's right above the drivers side rear wheel hump. Just pull the carpet out/down and you'll see the box. There are 2 plugs for the antennas, IIRC yellow and green, both about 1/4" in size.
Old Oct 10, 2011 | 04:15 PM
cstapp99's Avatar
cstapp99
Thanks. I wish it were that easy. The car is out in the wide open. I did check the connections - everything looked good there.
Old Oct 10, 2011 | 04:18 PM
kedar's Avatar
kedar
St. Jude Donor '12
Can you change stations? I think you may have to leave the radio on channel one for the receiver to get data from the satellites. Set the car to channel one the next time you are driving around.
Have you called XM regarding this problem? Its possible that XM has to re-send the activation signal.
Old Oct 10, 2011 | 04:21 PM
cstapp99's Avatar
cstapp99
I left the radio on channel 1 for close to an hour this morning - no go. I'll try to call XM and see if they can recommend anything.
Old Oct 10, 2011 | 05:12 PM
cstapp99's Avatar
cstapp99
Called XM. They were very helpful but to no avail. I got excited for a brief second when they "reset" my radio - there was a message on the screen that read "loading XM" followed by about 2 seconds of audio on the preview channel, then static, then back to "no signal." Dang. She told me the next step would be to take the car to a professional tech and have the module checked. Grrrrrrr!!!!!!
Old Oct 11, 2011 | 10:53 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
cstapp99,
This is a known problem in the c6 Corvettes. We're currently working to resolve it. We'll keep you updated when a resolution is reached. Thanks for your patience. In the meantime, please don't hesitate to contact me directly with any questions, comments or concerns about your vehicle.
Chevrolet Customer Support,
Justin
Old Oct 11, 2011 | 11:00 AM
cstapp99's Avatar
cstapp99
Originally Posted by Chevy Cust Svc
cstapp99,
Justin
Thanks Justin. I had planned on taking the car to a dealer next week to have the XM system diagnosed. Should I wait?
Old Oct 11, 2011 | 03:51 PM
Chevy Cust Svc
Default Xm
cstapp99,
While this is a known issue; I believe at this point in time they're dealing with it on a case by case basis. With that being said, I'd recommend taking it to the dealership. I can help you setup an appointment if you like. As always, feel free to contact me with any questions, comments and concerns.
Chevrolet Customer Service,
Justin
Old Nov 13, 2011 | 06:45 PM
rdavidharris's Avatar
rdavidharris
8th Gear
I have a 2009 GMC Sierra truck with OEM XM Radio that has worked perfectly for two years and now it says No XM Signal as well. Of course I called XM and they did their usual 'reset' thing. No fix. I seriously doubt this is a GM/Radio problem. However, since there are no English-speaking Americans at XM tech support they just go by their script and pass the blame onto someone else.
I have noticed many recent reports of XM service outages in the past couple of months. Anyone get any real answers regarding this issue?
Dave
Atlanta GA
2009 GMC Sierra 1500
To XM - no signal
