Sponsored by: Innova
Which PAC steering wheel interface?
Old Nov 6, 2011 | 05:47 PM
jpuli28's Avatar
jpuli28
Default Which PAC steering wheel interface?
I have an 07 with no steering wheel controls. I purchased an '11 wheel with Bluetooth and radio controls. I have a Pioneer AVH 4100DVD already installed, which PAC model do I need, PAC 127 SWI-PS?
Old Nov 7, 2011 | 08:52 AM
ZAKsPop's Avatar
ZAKsPop
I settled on the C2R-GM24.
Old Nov 7, 2011 | 10:07 AM
jpuli28's Avatar
jpuli28
Are there already wires for the wheel in the steering column and behind dash? So depending on your option pkg you get the different wheel?
Old Nov 7, 2011 | 04:46 PM
markcz's Avatar
markcz
Looks like the PAC SWI-PS is the module you need to connect your new wheel to the radio. Check with C5 BearsFan, he knows all of the latest changes
To get your new buttons functional I believe you'll have to replace the clock spring under the wheel. Search the C6 gen and tech sections, I know there have been others do that mod and post about it.
To see if you have the needed wires in your radio harness, look at pins A6 and A7, if there are wires there you're in luck. If no wires, you'll need to run a set from the SWI-PS to the new clock spring.
That's the interface adapter to connect a radio to the car, he already has that.
Old Nov 7, 2011 | 05:07 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
swi-ps or RC
PAC has changed the SWI-PS and JACK to the RC to work with both KEnwood and Pioneer
You can also use the MEtra ASWC
on the Pioneer I like the mEtra ASWC better as its self programming.
Old Nov 9, 2011 | 08:57 PM
ZAKsPop's Avatar
ZAKsPop
My bad. I got the Axxess ASWC steering wheel interface.
To Which PAC steering wheel interface?
