Sponsored by: Innova
Grounding to Battery
Old Nov 14, 2011 | 02:32 PM
lionelc5's Avatar
lionelc5
Default Grounding to Battery
Is their any cons to running a ground back to the battery besides the cost of the wire? I will be running 3 amps, 2 - JL HD 750/1 and a JL HD 600/4.
If I ground in the normal location I may be running a longer ground than is recomended, so I was thinking I would just run a ground from the battery when I run my hot.
Any reason this is a bad idea? I just dont want to deal with any ground loops or "engine noise" so why not nip it in the bud from the get go?
LionelC
Old Nov 14, 2011 | 04:01 PM
markcz's Avatar
markcz
Where will your amps be mounted?
In general, you should make the ground wires as short as possible to help prevent noise in the system, however, if you ground all 3 at the same point it shouldn't really matter much where that point is.
Old Nov 14, 2011 | 05:02 PM
lionelc5's Avatar
lionelc5
Amps will be in the hatch area just behind the seats. I planned on just running a 0 gauge from the battery and using block to split off three 4 gauges, one to each amp.
Old Nov 14, 2011 | 05:05 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
fyi running a ground straight to battery doesnt mean you wont have alternator wine
Old Nov 14, 2011 | 06:12 PM
lionelc5's Avatar
lionelc5
Thanks, that is the answer I was looking for.
I know about keeping RCAs away from power wires and such, and you always hear about bad grounds, so I wondered why no one just ran a dedicated ground. If it doesnt fix a problem they why do it....
Thanks,
Lionel
Old Nov 14, 2011 | 06:29 PM
Thrash's Avatar
Thrash
Thanks,
Lionel
FYI: There are several threads here (in the FAQ as well) about grounding each RCA neg to the chassis to reduce noise ...
Old Nov 15, 2011 | 06:25 PM
frenchsquared's Avatar
frenchsquared
I just did exactly that. I had terrible amp feed back. The rca wires were not top of the line
but not cheap ones. Same setup in another car no feed back.
Anyway, I replaced the rca wires with high end ones from radio shack... I know..
but they actually had a nice set.
I ran the rca wires on the passenger side, power and ground on the drivers side.
Not a bit of feedback this time.
Old Nov 16, 2011 | 01:45 PM
lionelc5's Avatar
lionelc5
I did a little research at DIYMA and found that running a ground back to the battery is farily common, but mostly with large SPL systems. They do it to help with amp drop due to the heavy loads. Even though I will have 3 amps with a total of 2,100 watts it doesnt look like I will have any trouble with that.
That being said, I will go ahead and run the ground all the way, mostly because I already have the wire and distobution block to do it.
Thanks for the advice,
LionelC
To Grounding to Battery
