Sponsored by: Innova
Gun Shot
Old Nov 14, 2011 | 10:23 PM
pajac42's Avatar
pajac42
Default Gun Shot
1999 C5 coupe. Stock Bose system. I am getting an intermitent gun shot sound that seems to come from the right rear seaker. Hard to tell in the in the closed space. All speakers seem to function normally, otherwise. ANY THOUGHTS?:
Old Nov 18, 2011 | 08:38 PM
pajac42's Avatar
pajac42
Guess there are no thoughts in this forum.
Old Nov 18, 2011 | 09:58 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Here's a thought.........stop taking that shortcut through the 'hood' and the gun shots might stop.
J/K
Old Nov 18, 2011 | 10:32 PM
markcz's Avatar
markcz
Could be a blown speaker. Adjust the fade/balance so you only play 1 speaker at a time and crank up the volume, if it's blown you'll hear it
Old Nov 18, 2011 | 10:35 PM
dobber's Avatar
dobber
Are you playing 50 cent? If so, could be normal...
No really, best advice I can give you is to listen to MARKCZ. He is a genius with this audio stuff.
Old Nov 19, 2011 | 11:34 AM
Thrash's Avatar
Thrash
It might be a short, some bare speaker wire that is bouncing around somewhere ...
Old Nov 19, 2011 | 05:45 PM
pajac42's Avatar
pajac42
Thanks Guys. Each speaker seems to be functioning normally. I am assuming that it is a loose connector or an intemitant short somewhere. I was hopping someone else had encountered the problem and had a place to start.
Old Nov 19, 2011 | 10:20 PM
RAAMaudio's Avatar
0RAAMaudio
Former Vendor
markcz, great advice, as always
If that does not find the problem, it could be deeper and some of this can get a bit involved but always start at the problem end, go to the middle, then in between, etc, best trouble shooting thing I learned in my 20 years as a tech in the Navy, called half stepping. Not exactly applicable here but can be of some help.
In your situation, seems rather random, disconnect one rear speaker, if the problem comes back, it is the one that is hooked up, if not, the one you disconnected. (or channel, earlier in the chain)
No luck, swap speakers side to side, test again.
Next, not as easy, have somebody moving the wires around at the connectors in the circuit to see if a loose one, while you are playing the system, see if that causes it. (previously it would be of been good to note if while driving, parked, etc)
If you cannot cause it to happen then it could be prior to or at the amp, swap pins at the connector input, etc....
I could recommend many more steps but these should help narrow it down, sounds more like a blown speaker but you never know until you test it out, sometimes.
If anything I said makes no sense, obviously in error, etc...it is Saturday night after a very very long week, having some fun here
Rick
Old Nov 24, 2011 | 10:06 PM
pajac42's Avatar
pajac42
I appreciate the help. If, and when, I come up with a fix, I will let everyone know what I found.
Old Nov 27, 2011 | 07:11 PM
Jimsan's Avatar
Jimsan
For your consideration:
I have an '05 coupe, with factory Bose 6 CD. While on a road trip, the gun shots from the speakers. Worked fine for a while, then gun shots again and door speakers started hammering. Then all of the speakers began to hammer. Cause--amplifier self-destructing. Further comments from repair shops, etc, finds that the Bose amp has a proprietary chip, can not be repaired. All you can do is replace the amp.
Old Nov 28, 2011 | 02:24 PM
pajac42's Avatar
pajac42
Thanks Jimsan. It is still very intermitant, but has started to do it in quieter multiples - car running but not moving.
To Gun Shot
