Sponsored by: Innova
HELP.....again lol Bluetooth drama
Old Dec 15, 2011 | 04:47 PM
labworm's Avatar
labworm
Default HELP.....again lol Bluetooth drama
The bluetooth car kit is intsalled
The DPDT Relay works great and mutes the bose amplifier when a call comes in.
It cam with an external speaker which I cut off and successfully tapped the left door speaker Light Blue, Dark Blue, wires...The relay works well and everything is fine BUT I do have two concerns
1 --- When I try and split the signal coming from the bluetooth kit I keep getting distortion, either I am tapping the wrong wires for the Right low range (schematics say orange and dark green on the A -row of C2 (i have premium so I am readed U65) or I am not splitting the wires correctly to travel from one speaker to two speakers... IDK SMH
2-----Most Importantly and Lastly, when I turn off the car, the unit makes a drainage of power sound coming out of my left mid range speaker, which I have successfully tapped into for phone calls. Is there anything I can do to avoid this power drainage noise? It sounds like air being let out of a balloon (an electric balloon)...
- Should I install a second relay which mutes the bluetooth's audio signal when it is not receiving a call, that way that noise wont go through my car door speakers when power starts and ends in the bluetooth unit.
Old Dec 15, 2011 | 06:14 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
why are u using the low range speakers, you want to use hi range
Old Dec 15, 2011 | 07:44 PM
labworm's Avatar
labworm
Sorry I meant mid-range, I tapped into midrange left output
To HELP.....again lol Bluetooth drama
