Sponsored by: Innova
Will two 10" subs...
Old May 10, 2002 | 03:50 PM
RoliO's Avatar
RoliO
Default Will two 10" subs...
fit in the rear well of a C5? I'm currently running 4 JL 10's, and although they sound great, it is a little too much for me now. :( I think two 10's will be perfect but I'd like to conceal them if possible. Anybody have pics of a set up like this? My 4 10's are in a glass box that sits along the back end of the car. Anybody interested in this box? I'll be keeping the subs tho. :D
Old May 10, 2002 | 05:56 PM
y2kylwc5's Avatar
y2kylwc5
Default Re: Will two 10" subs... (RoliO)
What is the mounting depth of the subs you plan to use? If you want to conseal them the maximum height (to be completely level is about 9 3/4 inches, but is only in the rear most section of the well and only extents only 6 - 7 inches. I don't have the measurements in front of me right now, so I'm going on memory, so don't quote me. The subs may have to be placed off-setting each other in the enclosure just to get them to fit. If you want to conseal them the internal volume of the enclosure will have to be right on the money. Do you know how much volume you subs need? If you post the specs on the subs I may be able to help you design an enclosure. I have a 12" Polk Audio Momo series sub that I can hide with the compartment cover, if I want.
Old May 10, 2002 | 11:25 PM
RoliO's Avatar
RoliO
Default Re: Will two 10" subs... (y2kylwc5)
I don't know the sub specs. :( They are the JL W0's. If I can't fit two 10's then I will consider a single 12". :)
Old May 11, 2002 | 12:55 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Uhh, your kidding right? Just playing.
2 10w3D2's
Should be no problem to do 10's or even one 12.
Old May 11, 2002 | 01:56 PM
RoliO's Avatar
RoliO
Default Re: Will two 10" subs... (JoeyG)
2 10w3D2's
Kick ****! Thanks for the pic. I would prefer to do 2 10's. :cheers:
Old May 13, 2002 | 06:34 PM
molon labe's Avatar
molon labe
i've got two 10"'s in back. pic below, and more at http://www.kcpimp.com/vette/
Old May 14, 2002 | 12:44 AM
RoliO's Avatar
RoliO
Default Re: Will two 10" subs... (tattooed)
It's amazing how many people run JL subs! :p: :p:
To Will two 10" subs...
