Sponsored by: Innova
Setting a PAC ROEM-VET1
Old Jan 14, 2012 | 04:47 PM
X-Ravin's Avatar
X-Ravin
Default Setting a PAC ROEM-VET1
Ok so I did the usual HU upgrade while leaving the Bose system intact by using the PAC ROEM-VET1. After putting things back together and adjusting the EQ to try and get a decent sound I found there was nothing I could do to get the highs to come out. It sounded like crap!
So I searched the boards and found I'm not the only one. I saw explanations ranging from: it doesn't use the tweeters, it bypasses the DSP which adds highs to the sound, it works just fine, install new 3" speakers and it works, etc.
Today I pulled it all apart and started messing with the adjustments on the adapter. Here are my findings for those who walk this path in the future:
1. The rears are unaffected by the pots
2. Only the front sub woofers are adjusted by the front pots.
3. The tweeters are controlled by the HU
4. The initial pot setting has the subs CRANKED
Thus the reason the sound sucks is because say at volume 10 the subs are at 20 and the tweets at 2 (simplified, yes I know, but the point it there). So what I did is:
1. Adjust the fade all the way to the front.
2. Turn front pots all the way down (no signal to the subs).
3. Turn up the HU to hear the tweets.
4. Start turning up the pots to add bass.
5. Fade back to center.
FWIW I found 12 o'clock to work well with some EQ on the HU. I hope this helps people in the future!
Old Jan 15, 2012 | 12:41 PM
markcz's Avatar
markcz
Good info
Old Feb 2, 2012 | 12:21 AM
BoostedEBZ06's Avatar
BoostedEBZ06
How do you adjust it on the ROEM VET1? All I have are these four holes in it there aren't any ***** or anything.
Old Feb 2, 2012 | 12:22 AM
X-Ravin's Avatar
X-Ravin
If you shine a light in there you'll see little ***** you can turn with a very small flathead.
Old Feb 2, 2012 | 12:50 AM
BoostedEBZ06
Got it! Thanks.
Also if you could help me out with this issue?
http://forums.corvetteforum.com/audi...g-problem.html
Old Mar 16, 2012 | 10:41 PM
CatCam's Avatar
CatCam
Thanks X-Ravin. I did this upgrade as well and have had the same issues with sound. The Pisser is that the PAC ROEM VET1 does not come with any instructions to set the damn thing. I ASSUMED it was a "plug and play" from the factory. THIS IS NOT THE CASE. I was so frustrated I had another PAC harness sent to me because I had ZERO Hi-frequency sound. Now I have the highs but the bass needs to be set up.......I will pull apart my Bezel AGAIN to get to the damn interface to adjust it.......
Knowing what I know now I would have left my stock HU in.
I'll post back again after I **** with this thing again....but I'm taking a break for a week or two.......
Old May 1, 2021 | 07:21 PM
6spdg37s's Avatar
6spdg37s
I set mine following the instructions here... worked perfect only took about 20 seconds to get it set right. the guy that works for me was like wow what a difference.
Old Jul 12, 2024 | 10:21 PM
U1_'s Avatar
U1_
12 years later, same problem, same solution. It blows my mind that they haven't put this in the "manual"...
Either way, thanks. This definitely made my day!
Old Feb 4, 2026 | 12:17 AM
RicardC5's Avatar
RicardC5
Default Upgrading heads up
Hello!
I'm searching for some tips on installing this PAC ROEM-VET1 interface. This one is very valuable!
When I purchased, I was thinking it would be PNP... It hasn't been delivered yet, and I'm thinking about keeping the stock CD player...
To Setting a PAC ROEM-VET1
