C5 Audio...
If you want to go double-din, kits are available for that also. Click here
Get a stealth SUB BOX and find a sub that fits and is a good match to the amp you get. Or you can DIY the box
Front speakers would be 6.5" components on new mounting plates. $150-200 gets some nice speakers.
Sub + fronts can be powered by a 4-channel amp with 1+2 for fronts and 3+4 bridged to sub. $200 gets a pretty decent amp. Make sure of ohm rating of sub if you bridge channels.
If you want rear speakers, get coaxials for about $100, then use a 5-channel amp.
The possibilities really are endless
Contact member C5 BearsFan and he can hook you up with everything you need in one box
The new kenwoods are awesome The system I am putting together is under $1000 and should sound good the whole setup is:
Kenwood KDC BT-952HD Radio
Kenwood XR 5S 5 Channel Amp
Polk DXi 10" DVC subwoofer
DD Mods Stealth Box for Sub
Polk DXi 6.5" Two ways for rear
Arc 6.5" Components for front doors
HUMount Installation Bracket
Hope this helps
Eric
