Sponsored by: Innova
GM-Bose Interface adapter problems
Old May 15, 2002 | 07:16 AM
Villain's Avatar
Villain
Default GM-Bose Interface adapter problems
OK, here's the deal, pickles. Everything is not kosher.
I bought a Pioneer DEH-P77DH head unit so I could add an XM tuner to my system. Ordered the speaker interface adapter and wire harness from Scosche. I figured I would put up with the Bose speaker thing for a while and change them later.
I completed the hook up and found that: 1) the wire harness, although they said it would work with my car, did not work completely. I had to run a separate 12volt line to the radio for accessory power, otherwise the radio just would not power up through the harness. The harness was model GM02 just incase you had plans to buy one and would like to change your mind.
2) The interface adapter could not put out enough signal to bring the volume up above normal conversation levels, even with the head unit volume on full. The interface model is FAI-3.
Can anyone offer some assistance on this issue? I've read all of 99HT's info on the Bose system and I can't get this thing to put out any good sound.
Ultimately, I do not plan to keep the OEM head unit.
Has later come sooner? Must I gut the whole thing and start with new speakers and wiring? :( :rolleyes:
Old May 15, 2002 | 09:59 AM
99HT's Avatar
99HT
Default Re: GM-Bose Interface adapter problems (Villain)
There is a PAC solution for what you want to do. Try searching for the info. It may work better than the adapter you have now.
Old May 15, 2002 | 02:58 PM
Villain's Avatar
Villain
Default Re: GM-Bose Interface adapter problems (99HT)
I'm not sure what you mean by a PAC solution. Is it something in this forum or on the 'net? What does PAC stand for?
Old May 15, 2002 | 04:49 PM
99HT's Avatar
99HT
http://forums.corvetteforum.com/zero...744676#2744676
Old May 15, 2002 | 05:40 PM
Villain's Avatar
Villain
Thanks 99HT. You're the man. I'll let you know how it goes. :cheers:
To GM-Bose Interface adapter problems
