Sponsored by: Innova
C6 upgrade advice
Old Mar 13, 2012 | 10:00 AM
ctaylor1432's Avatar
ctaylor1432
Default C6 upgrade advice
I have stock Bose with Nav and XM(2005). If I have about $800 to upgrade, where should I start?
Old Mar 13, 2012 | 01:22 PM
Thrash's Avatar
Thrash
Invest the $800 and wait for it to grow to about $5000, then start your upgrade.
Seriously, $800 would not do much for stock improvement, you need new speakers and amps. A new HU would be a waste w/o ditching the Bose. I'd use the $800 for sound deadening and stock speaker replacement from Dennis at DoubleD ...
Old Mar 13, 2012 | 04:29 PM
markcz's Avatar
markcz
If keeping the oem radio, $800 can do...
DIY ADD-GM24 adapter (see C6 audio sticky) $20
Cubby sub box w/10" sub $400 tops
Bridgeable 4-channel amp $200
Misc wires & amp kit $50
$130 left for 6.5" components in the doors
That would sound pretty good
Save up a bit more to get better components and it will sound great.
Once amp/speakers are done you can decide if you want a new HU while saving for it.
Old Mar 13, 2012 | 06:55 PM
WAwatchnut's Avatar
WAwatchnut
good advice.
If you increase your budget, it would allow you to go with better components for the fronts. That's the key. Changing from a $200 amp to a $300 amp won't buy you a big improvement in SQ, but going from $130 to $230 components will.
Old Mar 13, 2012 | 08:18 PM
ctaylor1432
Ok, can I give one of you the cash to do the purchases, since I really don't know crap.
Old Mar 13, 2012 | 09:58 PM
markcz's Avatar
markcz
Contact member C5 BearsFan, that's Dennis from DoubleDmods.com, he can turn your cash into actual gear
Old Mar 17, 2012 | 01:58 PM
tampatopless's Avatar
tampatopless
What do you guys propose about the rears and the center speaker? Leave the rears connected to the HU and disconnect the center?
Old Mar 17, 2012 | 02:23 PM
Orange06's Avatar
Orange06
The center speaker is pretty worthless. Disconnect. If you're doing a complete system replacement with a DVD deck and your system is capable of doing true 5.1, you could put a decent 3.5" speaker there.
Opinions are more divided on the rear speakers. Those that are going for optimum sound quality and imaging run without rear speakers and put high-quality component in the doors with plenty of power from aftermarket amps. If keeping the factory amps or doing a more basic system replacement, the rear speakers can provide "fill" and boost the volume of the system.
To C6 upgrade advice
