Sponsored by: Innova
Install pending
Old Apr 1, 2012 | 07:35 PM
Orange06's Avatar
Orange06
Default Install pending
I FINALLY received my 08 vert I've had most of the audio equipment for a couple weeks. I'm recycling the Polk MM6501 components and MM1040 subs from my coupe. I got my Arc amps (KS mini 125.4 and KS 600.1) plus door baffles and sound deadening from Rick at RAAM Audio. The head unit (Pioneer AVH-P8400BH) and associated harnesses are coming from DD Mods. The forum vendors have been a fantastic resource for getting an excellent sound system in my Vette Rick and Dennis have been awesome at answering all my questions.
I ordered the Vette Nuts sub enclosures for the subs, then found that my Polks don't fit. The basket on the Polk subs doesn't taper enough compared to the JL subs for which the enclosures are designed. I might use spacers to raise the subs so they fit. Marc at Vette Nuts has been really helpful. The other alternative I'm looking in to is a local shop that offers custom fabrication to put 10" subs behind the seats.
I can't give enough credit to the great vendors here. Anything from a basic speaker/HU swap to a full out competition level system, they can set you up!
Old Apr 2, 2012 | 09:38 PM
v8rx7com's Avatar
v8rx7com
Originally Posted by Orange06
I FINALLY I'm recycling the Polk MM6501 components and MM1040 subs from my coupe. I got my Arc amps (KS mini 125.4 and KS 600.1)
First, congratulation on getting your vert
how are you planning on running your MM6501s?
The Arc mini 125.4 bridged into 2 channels is recommended to be ran at 4 ohms X 2 channels and the MM6501s, are 2 ohms components
Just curious on what configuration (2 or 4 channels) you are planning running the Arc mini 125.4?
Old Apr 2, 2012 | 11:44 PM
Orange06's Avatar
Orange06
I'm going to run each driver of the MM6501s off a channel from the amp. The 125.4 I have is modified by Arc to put the crossover range in the right area for a mid/tweeter split.
Old Apr 4, 2012 | 11:01 PM
SDB_FTW's Avatar
SDB_FTW
I almost feel the need to apologize to Rick and Dennis for not discovering them before I built my system, dangit.
I was looking at pics of the vettenuts sub boxes, and it looks like you have room for a spacer of up to around 3/4" without interfering with the roof mount, based on the picture below. It would suck if after all the money you spent on the boxes that you'll have to offload them and fork over some serious dough for custom work. Spacers are also really, really easy to fabricate, if you wanted to do it yourself.
Old Apr 5, 2012 | 01:30 AM
Orange06's Avatar
Orange06
I'll have a chance tomorrow to check out the local shop and ask what a custom enclosure would cost. My ideal placement would be the subs behind the seats and the amp under the partition between the trunk and the convertible top. I don't have to worry about storing a targa top, so spacers will fit if I modify the Vette Nuts enclosures. Worst case, I can use my Subthump box for a while.
Old Apr 5, 2012 | 02:06 AM
WAwatchnut's Avatar
WAwatchnut
There isn't really much space above the speaker due to the angle of e box. I couldn't use it because my woofer rubbed against the frame of the top when it was stored. If you add a spacer, and the sub sticks up much beyond the surface of the box, it may not work.
Old Apr 5, 2012 | 09:00 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
If you have a vert the box you have should look like this one which can handle a little bigger sub depths and magnets. We will be happy to do all we can to help.
Old Apr 5, 2012 | 10:06 AM
Thrash's Avatar
Thrash
My VetteNuts pods fit great and the Pioneer TSSW251's sound awesome! Dennis at DoubleD was great on my install, as was Rick at Raam
Old Apr 5, 2012 | 01:16 PM
Fasthotrod's Avatar
Fasthotrod
Looks good, Thrash.
Old Apr 5, 2012 | 07:47 PM
Orange06's Avatar
Orange06
The local shop quoted me $1200 for a custom box to put 10s behind the seats. They do top-notch work, but that's quite a bit more than I want to spend on an enclosure right now. That much $$$ would buy a processor, Wind Restrictor, better speakers, etc.
I just tried the boxes I had from the coupe and found they don't fit into the convertible trunk. Back to square one...
To Install pending
