Sponsored by: Innova
Improving your sound system on the cheap
Old Apr 6, 2012 | 09:17 AM
Never-Enough's Avatar
Never-Enough
Originally Posted by sportcruiser
I don't know, I listen to mine with the top off all the time. It could be better I suppose, but it's not bad (mine is not the Bose upgrade). In any event, the point of my post was that playing a CD will get you a major upgrade in sound versus an iPod or other mp3.
I can barely hear it w/the top off & windows down. As soon as I find a deal on a corner sub box & sub, I'm upgrading mine.
Old Apr 6, 2012 | 09:32 AM
sublime1996525's Avatar
sublime1996525
So is there a way to upgrade the iTunes quality or are you pretty much stuck?
Old Apr 6, 2012 | 09:43 AM
Boz86's Avatar
Boz86
I was looking forward to audio dvds being another step up in quality, but the market seems to have gone down the ipod/mp3 player route.
Old Apr 6, 2012 | 09:45 AM
franman69's Avatar
franman69
Originally Posted by Vette5.5
If you think CD's sound good now, you should hear some of the properly mastered CD's of the 80's & 90's. Truth is all modern pop recordings regardless of the format, are severely dynamically compressed, and bass boosted, to play loud and boomy, through a 9 year old kids ear bud speakers. I have high end home audio equipment, and find all of these modern recordings totally unlistenable on it.
That's the fact Jack!!
Old Apr 6, 2012 | 10:02 AM
Speedforhire's Avatar
Speedforhire
No,no,no. CD is MUCH better than iPod. This was the point of my post.
.........you will not get any better quality than an oem MASTERED cd................it's the bit rate that makes it better.
Old Apr 6, 2012 | 10:21 AM
hihoSilver's Avatar
hihoSilver
what i found was the more you turn it up, the more the center dash speaker overpowers the rest of the system which leads to a mid range trainwreck. The center channed is flat and seems to have a higher set volume than the other speakers. By disconnecting the center channel, it was almost like having a new system. I can now turn up the volume enough to get the bass I want without getting the screaching center channel headache. Its easy to test, throw in a cd or mp3 and cover the dash speaker with a pillow or whatever yo have that will kill the sound. To me, it made the difference of replacing the whole system which I was ready to do. The xm radio still sounds like crap, but this will help the overall sound. This is just my opinion.
Old Apr 6, 2012 | 10:24 AM
Speedforhire
Originally Posted by WAwatchnut
... garbage in, garbage out..............Try ripping music in a lossless format................
..........this is probably the simplest way to explain it but you are correct...........wma lossless would be the best..........
Anyway.........my vert has the BOSE 9 speaker upgrade and I notice that when I put the top down it boosts the audio output automatically.........any of you guys with verts experience that?
Old Apr 6, 2012 | 10:54 AM
StanNH's Avatar
StanNH
Originally Posted by jack5hd
old vinyl ..still sounds good
I hear the new C7 will have a built in turntable.
Old Apr 6, 2012 | 11:51 AM
rz2mbc's Avatar
rz2mbc
Originally Posted by Never-Enough
The stock Bose system still sucks. Forget about enjoying anything w/the targa off & windows down.
just turn the volume **** UP......thats why its there. Top off, cruising, sound of the aftermarket exhaust & volume cranked !!
Old Apr 6, 2012 | 12:09 PM
EVRose's Avatar
EVRose
At full volume the Bose system isn't loud enough to override a normal conversation ... that's coming from the car next to you with their windows up. It's almost like it was designed for people with hypersensitive hearing or something. The amp and speakers are total garbage. When I first got mine my wife asked me to turn up a song she liked and it was at full volume already. Even she, who hates LOUD music, thought it was bad.
Old Apr 6, 2012 | 12:20 PM
red2012's Avatar
red2012
not when i burn music. putting the i pod through the required programs when you are putting music on it (EQ, DYNAMIC RANGE EXPANDER ETC,)where you can tailor the sound as your putting it on the i pod far exceedes the cd quality in store bought music. most music for that matter. its all in the recording.
Old Apr 6, 2012 | 12:22 PM
Scott Simpson's Avatar
Scott Simpson
Whether you can tell the difference in bit rates will depend on how good your hearing is and how old you are. Your hearing gets much worse with age. That is just biology. There is an app in Appzilla on the iPhone where you dial in your age and it plays a noise appropriate for your age. Unfortunately I can't hear the one appropriate for my age. I can hear the next age up. My cats can hear all of them.
Old Apr 6, 2012 | 12:49 PM
  #33
red2012's Avatar
red2012
i have all my 70's music on vinyl and inmop nothing compares to it. the incredible crisp highs without sounding harsh make the difference.
Old Apr 7, 2012 | 07:20 AM
  #34
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
How about this. Take a nice marbled steak. Put it on the grill and cook it just right. Take a bite. Good? Now run it through a meat grinder, soak it in Drano, and throw it in a dumpster. Come back 3 days later. Is there anything you can do to make it taste as good again?
The reason lossless encryption is called lossless is because it doesn't lose anything. ITunes loses a lot to make the files smaller. Once it is lost it can't be found again. There is also a big difference in creation software as to what they keep and what they lose even at the same bit rates. The MP3 standard only defines how to decrypt the data file. It says nothing about how to convert audio to a data file. What is kept and what is lost is up to the software author. ITunes keeps boomy base and tinny highs at the expense of making the middle muddy. There is as much difference in encryption software as there is in playback equipment. All MP3s are not created equal.
Old Apr 7, 2012 | 07:58 AM
  #35
Dans C6's Avatar
Dans C6
I must admit xm =crap. I wish they would stop sending me those stupid letters in the mail. Also they call too often, and I tell them to shove it you know where.
Old Apr 7, 2012 | 08:25 AM
  #36
Tide Will Roll!'s Avatar
Tide Will Roll!
So when I load a store bought CD on my iTunes, and then make a copy of that store bought CD...the copy will never sound as good as the original because itunes is degrading the quality?
I am obviously clueless about the whole process
I mostly listen to the ipod using a Pac2 interface, but also burn CD's, until I get burnt out on them.
That type ipod interface is much better than using the jack on the car radio to plug in the ipod, correct?
Last night I made CD's, Led Zeppelin and James Brown
Still blows my mind how many great songs JB had made, he was Superbad....
Bert
Roll Tide!
Old Apr 7, 2012 | 10:33 AM
  #37
Vette_DD's Avatar
Vette_DD
Originally Posted by TRUOMEGA
Sorry to hijack the thread but does anyone else get a hissing sound with the stock bose system? The louder i raise the audio, the louder the hiss from the speakers.
Usually better to start a new thread when it's off the subject. Might even get better responses for this subject in the Audio/Electronics forum.
To Improving your sound system on the cheap
Old Apr 7, 2012 | 11:58 AM
  #38
red2012's Avatar
red2012
Originally Posted by EVRose
At full volume the Bose system isn't loud enough to override a normal conversation . The amp and speakers are total garbage. When I first got mine my wife asked me to turn up a song she liked and it was at full volume already. Even she, who hates LOUD music, thought it was bad.
i just don't get it. i consider my self to be somewhat of an audiophile and do play an instrument. so i know what i want to hear and for the most part the bose delivers. on my 12 coupe with the PROPER RECORDED material the bass rocks the highs are crisp and the volume is plenty. alot of people trash the bose and i was ready to cringe when i turned it on for the first time when i took it off the showroom floor. not so. i dont know what type of media format you use to play your music or how good your recorded music is but my recorded music sounds nothing like you guys describe. at 3/4 volume on most of my good stuff you can not talk over it(and the quality is very good) nevermind full volume. maybe some people need to have their hearing checked(i just had a full hearing spectrum test done 6 months ago on my hearing so i know im good). the bose is plenty good of a system for me.
Old Apr 7, 2012 | 12:26 PM
  #39
05dsom's Avatar
05dsom
Originally Posted by Raazor
Sat Radio blows for sound
it's almost like AM radio
Lately I've just been using Pandora through my iphone4-USB connection (over 3G)....sound is MUCH better than XM and you can make your own stations and greater variety for music (but not sports, news,etc)
Old Apr 7, 2012 | 01:17 PM
  #40
QUAKEJAKE's Avatar
QUAKEJAKE
TO the Op, Do you have the Navigation unit? The no navigation Bose in my 06 coupe sounded much better. Trough my navigation Bose XM sounds the best followed by Pandora through my hand held followed by a CD.
