So when I load a store bought CD on my iTunes, and then make a copy of that store bought CD...the copy will never sound as good as the original because itunes is degrading the quality?
I am obviously clueless about the whole process
I mostly listen to the ipod using a Pac2 interface, but also burn CD's, until I get burnt out on them.
That type ipod interface is much better than using the jack on the car radio to plug in the ipod, correct?
I haven't used iTunes to rip music in quite a while so I can't say specifically how to do it, but it depends on the settings you use to make that recording. There should be different options, probably including Apple Lossless (which takes up a lot more space). The lower the compression rate, the better the sound, but the more space stuff takes. Once you've ripped the CD, whatever sound quality losses incurred are permanent... You would need to go back and re-rip the CDs to get a better quality recording.
It's not iTunes itself that's bad (okay, iTunes isn't great, but that's a discussion for the tweakers), it's really how it's set up. If you google "iTunes compression settings sound quality" there are tons of articles on how to improve the sound.
i just don't get it. i consider my self to be somewhat of an audiophile and do play an instrument. so i know what i want to hear and for the most part the bose delivers. on my 12 coupe with the PROPER RECORDED material the bass rocks the highs are crisp and the volume is plenty. alot of people trash the bose and i was ready to cringe when i turned it on for the first time when i took it off the showroom floor. not so. i dont know what type of media format you use to play your music or how good your recorded music is but my recorded music sounds nothing like you guys describe. at 3/4 volume on most of my good stuff you can not talk over it(and the quality is very good) nevermind full volume. maybe some people need to have their hearing checked(i just had a full hearing spectrum test done 6 months ago on my hearing so i know im good). the bose is plenty good of a system for me.
Maybe its been improved for 2012. I've never heard one but the one in my 05 was severly underpowered for my taste. I added 500watts, a sub in the rear and Polk components in the doors and it sounds awesome now.
The latest round of Bose gear is definitely different than in previous years.
A few weeks ago I traded in my '07 for a '12. The '07 stereo was 100% stock for my 150 mile drive back to the dealer. The '12 stereo was 100% stock for my return trip.
The '12 with 9-speaker system is definitely better sounding that the '07 7-speaker setup was (and I had the '07 sound-insulated quite a bit). It obviously has the two dedicated tweets in the dash that were added, and the door sub looks a bit different also (I briefly had the drivers door skin off for something else and took a quick peek at the sub). I can't say what changed, but the '12 version definitely looked more like a 'real' sub instead of that thing the '07 had.
I'm one of the first to help people mod their system, but IMHO the '12 system really wouldn't benefit much from the $50 3.5" mod in the doors. I have the speakers sitting in my garage, but I'll be leaving my stockers alone until I have time to do my complete 3-way active + sub system in a few weeks
Actually, it's not. ITunes purchased music is much worse than CD, but the iPod is just a playback medium... garbage in, garbage out.
Try ripping music in a lossless format, or at very least, in "High" quality MP3, with lower compression. You'll find the sound is much better when it's not compressed to heck... Like they've done with satellite.
There is some fidelity loss when you're using the headphone jack, or through some lower quality direct connections. But the iPod has a pretty good DAC built in, and the output is quite good (when the recording is).
It's not so much the Ipod as it is itunes. I download a lot of muisc from them just for convenience sakes but I can tell which songs I download and which ones I have transferred to my playlists from an actual CD. If it's from an actual CD the sound is quite good. I have also compared it to the CD and the CD does come out on top, but that's because of the transfer to another medium and then retransferring it to the ipod. You always lose a little when the transfers are done.
Originally Posted by Vette5.5
If you think CD's sound good now, you should hear some of the properly mastered CD's of the 80's & 90's. Truth is all modern pop recordings regardless of the format, are severely dynamically compressed, and bass boosted, to play loud and boomy, through a 9 year old kids ear bud speakers. I have high end home audio equipment, and find all of these modern recordings totally unlistenable on it.
This is why I say I don't really need a sub for the music I listen to. Most of it was not recorded in the manner they record today.
They always record muisc to be played back with the technology they are using at that time. This has always been the case and why the Beach Boys sound quite good in our old cars, but not as good as we remember it when playing them on the modern equipment.
They try to remaster it but it's impossible to get the true sound in the manner it was recorded.
There are a lot of variables involved in the quality of sound from XM and ipods. If your setup is FM Modulated, bluetooth or direct connect plays a major factor. Also, the quality of your radio itself has a lot to do with it. Most aftermarket setups that offer the direct connect option will produce a better sound quality. As many have stated, loose the stock and the bose.
A digital to analog converter would likely really clean up the iPod's sound, I've been thinking of getting one ($300 or so) to see if it makes much difference. Anyone used a D2A????
I don't understand how you are getting better results out of a CD than with a iTunes AAC file in a corvette lol. iTunes files are typically at a 192 Kbps rate where a cd is at a VBR. But you should not be able to notice a difference unless you are running a high end audio system.
