Sponsored by: Innova
C5 CD changer AUX
Old Jun 17, 2012 | 11:26 AM
Damillio's Avatar
Damillio
Default C5 CD changer AUX
I have a thought that the wires for the cd changer were ran through the car regardless of whether the option was ticked or not. If so, then I should still be able to use it as an AUX input.
Can anyone confirm/deny? Where is the stock location of the CD changer?
Old Jun 17, 2012 | 02:09 PM
markcz's Avatar
markcz
If it doesn't have a changer in the trunk (passenger cubby), then cable wasn't ran to rear of car from footwell. MOST C5 have it to footwell, IIRC 2004 doesn't.
You can prob find something that will work for you HERE
Old Jun 20, 2012 | 06:23 PM
Damillio's Avatar
Damillio
No wires in passenger footwell... Next step is finding a decent aftermarket radio with an AUX in and MP3 playback
Old Jun 20, 2012 | 08:02 PM
markcz's Avatar
markcz
If there are cables in the footwell they'd be very well hidden, usually taped to an existing wire run under the trim or in the upper left corner.
Old Jul 7, 2012 | 10:50 PM
fdxpilot's Avatar
fdxpilot
This is right. Mine were behind the fuse panel cover in the footwell and the carpet just at the back end of the removable panel. I did this mod (adding changer) on my 02 coupe. Here is a link from the ancient past with more info.
http://forums.corvetteforum.com/c5-g...c-changer.html
Old Jul 8, 2012 | 05:30 PM
Shyler's Vette's Avatar
Shyler's Vette
Not sure about this but if you are looking to keep the HU and want Ipod connections the PXDP with the PXHGM4 cable is the set up that you need for your car without the changer in the back. I ordered my parts and took apart my dash this morning. It was very simple. I was actually surprised at the ease in which it came apart.
Old Jul 9, 2012 | 12:57 AM
Damillio's Avatar
Damillio
I'll have to dig deeper for the harness in the footwell. I'd like to avoid removing the dash, but if I have to, I will replace the stock HU with MP3 play back and an external AUX in. With the price of those cables, that might even be the cheaper option.
Possibly stupid question - Will the PXDP / PXHGM4 cables work for anything with a 3.5mm input (Android phone)?
Old Jul 9, 2012 | 08:29 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
no but the PXDX option will
http://shop.doubledmods.com/ZUNE-C5-...?categoryId=-1
Old Jul 9, 2012 | 02:35 PM
Damillio's Avatar
Damillio
For $70, I'd rather replace the stock HU. Especially if I already need the dash removed. Is there an extra headache with swapping the HU (04Z06)? I have done several swaps before on my previous two vehicles (90s B-body) with no troubles.
Old Jul 9, 2012 | 03:39 PM
0Double D Mods
Former Vendor
you can easily swap head unit
but
you will also need a 40.00 harness to retain Bose speakers
so you will have more than just the headunit involved as well
I have many packages available for single din radios if you need pricing
Old Jul 9, 2012 | 04:36 PM
Damillio's Avatar
Damillio
Please!
I am looking for MP3 playback and AUX input at a minimum. Probably bluetooth as it is very difficult to talk, drive, and shift gears. And possibly Pandora.
To C5 CD changer AUX
