Sponsored by: Innova
Installing new system - need help!
Old May 25, 2002 | 01:10 PM
Ender85's Avatar
Ender85
Default Installing new system - need help!
I have an '89 vette coupe that I just bought. The original owner had a really nice Alpine system in it, but he had it removed because I didn't want to pay extra for it. I have the stock system, in a box. I have no idea how to install any of the components. Also, the stock system only has AM/FM Tape. I definately want a CD player in there. I think I'll buy a head unit and keep everything else the same. Those BOSE speakers are pretty good, right? Anyway, I need some help figuring how to install everything.
thanks,
marthpodi
[Modified by marthpodi, 5:12 PM 5/25/2002]
Old May 25, 2002 | 06:53 PM
Charlutz's Avatar
Charlutz
Default Re: Installing new system - need help! (marthpodi)
:lol: :lol: :lol: :lol: :lol: :lol:
Spend a little time on the board and you'll find out what everyone has to say about them. (I'm not making fun, I'm in the same boat.) There are a few threads going at all times on the board about replacing the bose. I'm doing mine now in my 86 vert, as are a few others in their c4's. You should actually be glad that you have a head start - someone's already taken out the old system for you. My advice is to ask around (on the board) or do a search of old threads, and consider buying a new system from the get-go, especially if you're already planning to buy a new head unit. The bose speakers don't hook up to non-bose head units without some modification, and then there are people who complain about the sound. Follow the lead from the previous owner - keep the bose in the box!
[Modified by Charlutz, 10:55 PM 5/25/2002]
Old May 26, 2002 | 12:01 AM
Ender85's Avatar
Ender85
Default Re: Installing new system - need help! (Charlutz)
Whoa....ok. What speakers should I get instead? I am looking for something cheap, and hopefully pretty easy to install. What do you think? I found a head unit online that fits the large slot used by the '89 vette. Advice/Instructions please!
marthpodi
Old May 27, 2002 | 02:26 AM
92TripleBlack's Avatar
92TripleBlack
First, skip the unit that fits the hole. If you are trying to save money or you want to get speakers, don't waste the money on a big head unit. Use a $20 dash kit and buy a din. You can then use it in a different car or resell it later because it will be compatible with almost every car. Also, you will be able to get the same features in a din unit for less than you spend on the big clunky one.
Second, C4 bose is a joke. Great for drop testing.
Step one: Drop on ground
Step two: If not broken, repeat step one.
How much money do you want to spend on everything?
Old May 27, 2002 | 11:52 AM
Ender85's Avatar
Ender85
Default Re: Installing new system - need help! (92TripleBlack)
under $400 if thats possible. The less the better for decent sound (I don't want the best or the worst) - no sub needed, just a head unit and front and rear speakers. I think 4' in the front and 6 x 9 in the back <-- but I'm open to suggestions.
thanks,
marthpodi
Old May 27, 2002 | 06:38 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Well an 89' with the original speakers? I would be willing to bet my tweeters that they are most likely blown, or damaged by now. I would recommend buying entirely news speakers. And if you decide to do so, make sure you dont use the prexisting wiring to the speakers, always use new wire. Good Luck :cheers:
Old May 27, 2002 | 06:46 PM
flannel_man
thanks,
marthpodi
Some say its all about the speakers. Well if you drop a $50 POS head in it dont matter how much you spend on the speakers it'll sound like crap. I would say plan on spending at least 300 for the head unit , and the other 100 on the speakers. Since you arent getting any Subs , I would say make sure you get a pair of 6x9's for some depth in the sound. The 4's will have about the same highs as the 6x9s , but you can tell the difference when it comes to the midrange and definately with the bass. Good luck. :cool:
Old May 27, 2002 | 10:51 PM
92TripleBlack
Default Re: Installing new system - need help! (flannel_man)
Get a Pioneer 4400 for $142 on http://www.pricegrabber.com and Boston Acoustics RX 97 and Rx 57 speakers from http://www.tms-electronics.com . It will sound great and is in your budget. It will also allow you to add a changer, sub, or amps easily later if you want to.
Old May 28, 2002 | 10:52 AM
Ender85's Avatar
Ender85
thanks! Don't I need some sort of conversion thing to get the regular sized deck to fit in the larger slot in my '89?
[Modified by marthpodi, 2:53 PM 5/28/2002]
Old May 28, 2002 | 02:23 PM
92TripleBlack
Its called a dash kit. $20 will make any din fit your dash and they are available at any car sterio shop, radio shack, best buy, etc.
Old May 28, 2002 | 03:13 PM
Ender85's Avatar
Ender85
Any one in particular, or all all dash kits basically the same?
Old May 28, 2002 | 10:10 PM
92TripleBlack
Different brands do it differently. You should look at a few to see how they look to you. Some mount the deck at the top or bottom of the opening. Others mount it in the middle. Still others mount the deck and have the space filled with some type of storage pocket. I made my own with a sheet of ABS interior plastic. I'm going to add the pocket when I find one I like. (picky) I'm also considering a DVD screen but I think I'd rather go for the 4.09 rear and other things first. Right now, its a race to finish this one before the C6 comes out and I want to start on one of those.
Old May 30, 2002 | 06:04 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
LOL well said!
METRA makes a great dash kit. Made of metal rather than plastic and is only about $20.00. You can get one at any Car Audio Shop or anywhere that sells car audio.
To Installing new system - need help!
