Sponsored by: Innova
subwoffer no sound
Old Jun 29, 2012 | 12:49 PM
hitmanpty's Avatar
hitmanpty
Default subwoffer no sound
Ok I have a head unid sony. 4 speakers and one subwoofer
I plug the speakers to the regular wireing of the head unit
but the sub woofer is conected as follow
with audio cables from head unit to low input on 4 channel amp (sony explod very old model) them I bridge channels 1 and 2 to subwoffer
the regular spekers sound ok but the subwofer it make no sound.
what Iam doing wrong
Old Jun 29, 2012 | 01:29 PM
EVRose's Avatar
EVRose
Do you have the gain set high enough on the amp? Do you have the sub volume set high enough on the HU? Is the amp getting power?
Old Jun 29, 2012 | 04:24 PM
hitmanpty's Avatar
hitmanpty
that volume on the HU I will check.
I have power on ammp ok
I think the protection light on the amp is on for some reason
Old Jun 30, 2012 | 01:44 PM
markcz's Avatar
markcz
Protection light:
How many ohms is the sub? What is lowest bridged ohm rating of amp? Do you have sub wired properly to amp?
No sound:
Is sub output turned on at HU? Is LPF on amp set too high? Is LPF on HU set too low? Are RCA's and speaker wires connected to same channels? Does amp have an 'input select' switch?
To subwoffer no sound
