Sponsored by: Innova
Question about the remote wire
Old Jul 8, 2012 | 01:49 PM
deJong's Avatar
deJong
7th Gear
Default Question about the remote wire
I am installing a Pioneer X930BT as well as a 4 channel amp and sub amp. I am ready to hook up the remote wire and want to ensure that I splice into the blue and white wire on the HU wire harness. Also, do I need to splice at the other end to run the remote power to both amps? I appreciate the feedback. Just don't want to make a mistake.
Old Jul 8, 2012 | 02:01 PM
needdlex's Avatar
needdlex
The remote wire is just a low voltage wire that gives a binary on/off signal.
I've never tried it before, but you can probably daisy chain a wire from one amp to the other one.
Old Jul 8, 2012 | 02:41 PM
hymnatr's Avatar
hymnatr
Yes you can
Old Jul 8, 2012 | 02:42 PM
markcz's Avatar
markcz
The blue/white is the amp remote wire, just make sure you don't use the antenna control wire by mistake (they're both blue/white).
You can jumper the trigger wire to as many amps as you want as long as it's just a trigger signal, don't try to use it as the actual power source to something (fans, lights, etc...).
Old Jul 8, 2012 | 03:21 PM
deJong's Avatar
deJong
7th Gear
Thanks guys. I only have 1 blue and white wire but it is wired this wayhttp://forums.corvetteforum.com/audio-electronics/2692118-pics-and-info-on-wiring-a-roem-vet1.html
I had Dennis a DD Mods do this for me. Now I'm definitely not sure which wire to use.
Old Jul 8, 2012 | 03:56 PM
markcz's Avatar
markcz
Thanks guys. I only have 1 blue and white wire but it is wired this way http://forums.corvetteforum.com/audi...roem-vet1.html
The link you posted is for ROEM connections. The ROEM is used if you want to replace the stock radio but keep the stock speakers. If you're replacing all of the stock speakers and adding a sub you don't need the ROEM. You can still use it for power and ground, but it isn't needed.
Connect the new HU yellow and black power wires through the roem. Connect the new HU red power wire to a switched source. The rest of the roem wires don't matter if you have new amps and speakers.
Run fused amp power wires from battery and frame ground to amps. Connect the new HU blue/white amp remote (possibly labeled P.Cont) to the trigger terminal on the amps (usually between the big power connections).
To Question about the remote wire
