Are two way fronts good enough or do I need a component set?
I just replaced my factory radio with an Appradio but the bose speakers sound as flat as a pancake through the Metra harness. Can I go with standard 2-way 6-1/2's or will it not sound much better? I am looking for factory grade audio, not really a purist and dont want to fork up the cash for a component set.
Can you tell if the door subs are working? When the new HU is installed you need to connect the 'remote amp trigger' wire to the car so they turn on.
