Sponsored by: Innova
C6 Volume controls
Old Sep 23, 2012 | 10:43 AM
Jaay2177's Avatar
Jaay2177
Default C6 Volume controls
My c6 does not currently have steering controls. Im thinking of getting a steering wheel from a model that does. Will it plug in? Is there a way to do this? Thanks.
Old Sep 23, 2012 | 12:27 PM
markcz's Avatar
markcz
At a minimum you'll have to change the wheel and clockspring (DIY thread HERE), but in order for it to work your radio would have to be one that is able to be controlled from the wheel. If you have an '05 I'm pretty sure it's not capable, after that I can only guess.
Search the forum for 'clockspring' in C6 sections, you may find info that will tell you if your car can do it.
Old Sep 23, 2012 | 12:29 PM
Jaay2177's Avatar
Jaay2177
Thanks. No i have a 2007.
Old Sep 23, 2012 | 12:41 PM
markcz's Avatar
markcz
Your '07 radio can PROBABLY handle the 5 remote buttons on the right wheel spoke, but you'll also have to verify that the car is wired from the steering column to the radio. If you pull the radio out and look at the big C1 plug, check for a purple wire at pin A6 and a dark blue wire at A7. C6 prints are HERE
Old Sep 23, 2012 | 01:05 PM
Jaay2177's Avatar
Jaay2177
Great. Thanks.
To C6 Volume controls
