Sponsored by: Innova
Battery terminal connections
Old Dec 11, 2012 | 03:27 PM
Joebrick's Avatar
Joebrick
Default Battery terminal connections
I am in the process of wiring a new sound system with the need to connect my amp positive and negative leads at the battery terminals.
When connecting 8 ga. 12V positive and ground to a side terminal battery, what is the best arrangement/hardware to connect?
It's a 73 coupe.
The side terminals are throwing me in terms of connectors....what to use?
Old Dec 11, 2012 | 05:11 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
go to autoparts store and get a gm sidepost terminal adapter. will look like this
http://www.jandawholesale.com/images...BTPSP-PAIR.jpg
Old Dec 11, 2012 | 07:22 PM
Joebrick's Avatar
Joebrick
Problem I have is my cable end is the old style with the rubber boot and bolt all as one end piece (original cable end). Would these extensions work with that application?
Old Dec 11, 2012 | 07:52 PM
markcz's Avatar
markcz
The bolt portion of the connector should be removable/replaceable. If you go to a local auto parts store they should be able to find a longer bolt that will allow you to insert a lug under it.
Old Dec 11, 2012 | 08:13 PM
pentavolvo's Avatar
pentavolvo
get some hot water on those rubber boots to soften em so you can pop the bolt out, they are a bear to get out but trust me they do
Old Dec 11, 2012 | 08:41 PM
Joebrick's Avatar
Joebrick
Perfect...that should work....thanks.
To Battery terminal connections
