Aftermarket nav install help
Dimmer wire is grey w/black stripe at TC/AH button. For steering wheel controls put 12v on to A6 and connect A7 to SWI device. C6 prints are HERE
I'm not sure what you mean by grounding straps, so you prob don't need them.
Plastic tabs on L shape Metra brackets are left/right ends of radio. If you're looking at front of bracket as it would be in the car the short ends of the L's go from inner part of radio face towards outside edge. You should see the slots they go in to. Once brackets are in place, then you can put radio inside and use screws on L brackets.
Radio RCA outputs plug in to C2R. C2R plugs in to big plug that's connected to car. Connect Red, yellow, black on C2R to same color wires on HU. Connect HU orange dimmer wire to TC/AH button. If rear camera see link above, post #2. Same post for VSS wire.
Dash instructions in Thrash's sticky.
If you get alternator whine you can use GLI's to eliminate it.
You also need an antenna adapter, but it's prob in the kit from DD.
That should cover just about everything
