Sponsored by: Innova
Help with Amp
Old Jan 6, 2013 | 02:01 PM
Maligator's Avatar
Maligator
Default Help with Amp
I purchased a JL stealthbox for my c6z, I am going to use the stock deck and only plan on using the amp for the subwoofer; the sub and amp will be the only addition to the factory system. Can anyone recommend a good amp? I should use a mono amp right???? The amp power ratings need to match that of the JL sub correct? Thanks! (car audio is not my strong suit!)
Old Jan 6, 2013 | 02:40 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
what is the rms of the sub and is it a SVC, DVC, 2 ohm, 4 ohm?
Old Jan 6, 2013 | 02:50 PM
markcz's Avatar
markcz
I believe the 'normal' sub that comes in that box is a single 4ohm coil rated 50-300wRMS.
I'd look for a mono amp with RMS rating in the 250-350 range AT 4 OHMS. Many (if not all) companies advertise amps at the highest RMS rating for the lowest ohm load that they're stable at.
Something like the Kenwood Excelon X500-1 is perfect. It's rated 500wRMS at 2ohms, but 300wRMS at 4ohms (that's what you need).
You'll also need to buy/make an adapter to get the signals from the HU (low freq signals are not present at the normal speakers). I'm using one of THESE
Old Jan 6, 2013 | 03:24 PM
pentavolvo's Avatar
pentavolvo
if its 4ohm sub a 2 channel amp will probally be less expensive for the power you need
Old Jan 6, 2013 | 04:43 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I have this amp and this harness instock
actually have the last 100 of these harness options that Pac Audio had ads I bought them all
Old Jan 6, 2013 | 08:20 PM
Maligator's Avatar
Maligator
thank you sir!!!
pm sent!!!!!!!!
Old Jan 8, 2013 | 07:58 AM
NYC6's Avatar
NYC6
I have a Stealthbox in my C6 and have it powered with a JL 300/2v2. Had the whole system powered with a 5 channel but on the recommendation of a JL executive down in Miami went with the 300/2. He was right, it sounds great.
To Help with Amp
