Sponsored by: Innova
Amp Install Problems - Need help from stereo gurus!
Old Jan 27, 2013 | 09:48 PM
AlabamaVetteFan's Avatar
AlabamaVetteFan
Default Amp Install Problems - Need help from stereo gurus!
Ok. I think the problem is with my "turn on wire".
My set up is as follows:
Aoem-vet1 harness
Alpine m50 amp
JL Sub
What do I with the green wire and what do i do with the blue wire with the white stripe?
Right now I have the green wire connected to the green wire on the black wiring harness.
The blue wire with white stripe is connected to the amp.
What am i missing here?
Old Jan 28, 2013 | 12:32 AM
markcz's Avatar
markcz
C5 prints are HERE
Somehow you need to trigger the amp to come on by connecting it to the dark green wire at pin 8 of radio plug C1. If you do it directly or through the aoem shouldn't matter.
Old Jan 28, 2013 | 07:15 PM
AlabamaVetteFan
much thanks! All i need to do is tune the amp/aoem...
To Amp Install Problems - Need help from stereo gurus!
