Sponsored by: Innova
Kenwood 1810 System help
Old Jan 29, 2013 | 05:35 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default Kenwood 1810 System help
Turned Vette on today and the Kenwood system is blank no radio no nav etc. the unit opens to insert cd but that is it. The red security light is on but nothing else. Any suggestions as to what is wrong.
Old Jan 29, 2013 | 08:42 PM
markcz's Avatar
markcz
Assuming C5 here
Sounds like you lost your trigger voltage. Without knowing how it was installed I'd start by checking fuse #11 in the footwell. If that's not it check all of the cars features to see if something isn't working, then check that fuse (wipers?).
If you don't find a bad fuse you'll prob have to take the dash apart to see if you have a trigger and where it comes from.
Old Jan 29, 2013 | 10:33 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
sounds like your battery was weak
disconnect battery to reset radio
reconnect
make sure its fully charged
the Kenwood should come back.
I have seen this many times when a Kenwood has low voltage to it
To Kenwood 1810 System help
